The reflective coating is silvering, there is no suitable alternative.
I’m refurbishing the headlights on my lbg 1950 80”. The glass is missing all the spring fasteners on one bulb, are these available or can I make some? Finding the right wire may be the challenge.
Also, the reflector bowls are very dull, even after a clean. Were these originally painted or coated with a reflective film? I’m not sure if they need polishing with steel wool or repainting. Is there a suitable highly reflective paint option available?
Thanks,
P
Mustlust
1950 Series 1 80in lights behind grill
1950 Series 1 80in rolling chassis looking for a body
1956 Series 1 86in
1956 Series 1 107
1957 Series 1 88in
1967 Mustang coupe 347 stroker
2011 Discovery 4 3.0
2009 110 utility 2.4tdci
Yes. They are electroplated with silver, and there is no realistic alternative. There used to be companies that would replate reflectors in nearly every suburb, but I have not seen one for decades, and I don't know if any still exist - they were killed by more permanent reflectors and relatively cheap replacement ones, and increasing restrictions on the highly poisonous chemicals used for occupational safety and environmental reasons.
If the silver coating on LBG lights is dull but still present, use 'Silvo' on a very soft rag.
.W.
The silvering is toast. I’ve chatted with Mario in the Sunshine Coast who will re-plate them.
Is the TEA-20 fergie light a direct replacement, looks very similar? I wonder if I can just swap out the lens for the original glass??
Mustlust
1956 Series 1 86in
1956 Series 1 107
1957 Series 1 88in
I’m thinking maybe the bowl in a new fergie light may be a practical swap. Comes with wiring and bulb as a bonus. May be that the lens springs are compatible also???
Mustlust
1956 Series 1 86in
1956 Series 1 107
1957 Series 1 88in
There's a good chance the Fergie lights are the same. Many other applications would be found, in that era, the lights being a generic Lucas offering.
		Why not just spray paint them with modern chrome paint - there are some paints just for this purpose - plenty of You Tube videos on doing it.
We are talking about a reflector that needs to form an accurate beam - no paint is even close.
The Ferguson lights, as I recall are very similar, but not identical. However, there is a very good chance the reflectors are interchangeable.
Paint didn't work for me.
.W.
