Results 1 to 6 of 6
Thread: Td5 tune info
    Jan 2013
    Mt Barker SA
    Td5 tune info
    Howdy folks my dad just bought another disco 2, manual one with loads of kms, looks like it's been looked after (even has a beautiful roof lining)
    From Mt Gambier if old owner here.
    I just plugged my nanocom into it, 1999 D2 td5.
    Is anyone knowledgeable on this tune? As in where its from perhaps. It goes awesome Td5 tune info
    Also is it possible to copy this file from the car to put in another disco?
    Thankyou
    Jun 2013
    Universe A
    Quote Originally Posted by Epic_Dragon View Post
    Thankyou
    As far as the info on the nanocom goes, that's a stock tune.
    But those numbers and letters don't tell you if the tune itself has been adjusted.
    As to whether it can be put on another car, yes it possibly can, but it would require a new chip being programmed and installing.
    Jul 2014
    west of Transylvania
    Thankyou
    Being from 1999 if it has the factory fitted MSB ECU you can't copy or write that "file" with nanocom, you have to remove the chip and "duplicate" it with a proper tool for that then fit that chip into the other MSB ECU... you can check if if your's was remapped cos then 99% the chip is fitted in a socket not soldered directly into the pcb, all you have to do is to remove the ECU's cover to see
    see this HOW TO CHIP LAND ROVER TD5 Defender and Discovery - YouTube
    Jan 2013
    Mt Barker SA
    Thankyou we will have a look! Only looked for if it had a tune/chip as it's really fast like my disco Td5 tune info
    The two d2a at home are quite slow Td5 tune info
    Back down the hill.
    You're just a hoon, or is that hooness?
    Jan 2013
    Mt Barker SA
    Haha i get it from my dad Td5 tune info I'm sad I cannot have a drive of this one myself Td5 tune info it's crazy, there's 5 D2s at home (one a wreck) and two d1s haha.
