Results 1 to 8 of 8
Thread: Gearbox id
    Dec 2010
    Kiewa Valley, VIC
    Gearbox id
    The gearbox that came with my 80” is no. 06110211, which is 49-50 correct. However, I have another that was in an 86” and that has no. 0609998. Now my understanding is that the numbers started at 06100000, so how can my gearbox predate that first 49-50 by 2 numbers?..
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Dec 2010
    Kiewa Valley, VIC
    This is a bit different to all the others I have. What is that lever?
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Jul 2009
    S.E.Qld
    A bit hard to tell from the picture, but it's one of these two.
    .W.
    Dec 2010
    Kiewa Valley, VIC
    I’m guessing it must be a ring pull box then. Unlike any I’ve seen before. I guess I’ll have to find a matching floor plate then.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Jul 2009
    S.E.Qld
    061..... were 1950, earlier ones 86....
    .W.
    Dec 2010
    Kiewa Valley, VIC
    Ok, that first number actually is 761…., so 1957 box.
    The other box is a stick transfer box that was the step between the ring pull and the usual S1 transfer lever arrangement. They simply changed the ring to a lever by changing the lever assembly at the front of the box.
    Learn something new everyday Gearbox id
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    JDNSW's Avatar
    Worth pointing out that the "ring pull" box is full time four wheel drive, with a free wheel device on the front output shaft. The ring pull locks the free wheel so you have four wheel drive in reverse.
    For a short period before the introduction of selectable four wheel drive the ring pull was replaced by the familiar yellow knob to lock the free wheel.
    Dec 2010
    Kiewa Valley, VIC
    Thanks John, I found the yellow knob stick (operating rod for lever) last night.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
