Series 2a Landrovers all had brakes that depended on wheelbase and number of cylinders.
SWB (88")    10"drums working surface width 1.5" one leading, one trailing shoe, same front and rear.
LWB(109")    Rear 11" drums working surface width 2.25" one leading, one trailing shoe
                    Front 4cyl. 11" drums working surface width 2.25" two leading shoe
                    Front 6cyl. 11" drums working surface width 3" two leading shoe
Drum diameter is measured across the inside of the drum, width is the lining width. 1" = 25.4mm
However, it is a relatively simple job to upgrade the brakes on a SWB Series Landrover by fitting LWB brakes, so you need to check what you have before buying parts. (This may have been done by a previous owner)
Also, note that Series 3 and the very last of 2a had larger wheel studs than earlier ones (16mm vs 9/16") so the holes in the drums for them are larger, and swapping hubs is even easier than brakes, so check this as well if getting new drums.
It is possible that your drums may have been refurbished to a slightly larger diameter, and in this case the new brake shoes must be finished to the same diameter (maximum permitted oversize 0.75mm)
