Results 1 to 10 of 15
Thread: 2000 discovery 2 A/C dramas
    Feb 2024
    Howdy everyone. I have just dove into the Landrover world and am loving it. I have a 2000 model Td5 discovery and am having A/C problems. The compressor is kicking in and running but the internal fan wasnt blowing so I replaced that thinking it would solve all my problems but am still not getting any air out of the vents? The internal fan is working now but nothing what so ever out of any of the vents. Is there somebody in the Gold Coast area I can possibly go to to get this sorted. Ive just replaced both front window regulators so I can wind down the windows now which definitely helps but I really want the A/C working.
    Cheers for any help !!
    Jul 2014
    west of Transylvania
    Hi, the aircon onthe D2 has it's own diagnostic protocol, first of all see if it shows any code or not
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by RoverDan View Post
    An adventure all its own....
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    BTW, welcome to the forum. D2s always welcome, pics also.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Apr 2016
    Country Vic.
    You said A/C, and air through vents: Does this mean that the issue is only with A/C and no air, or no air at all(irrespective) of A/C on or off?
    TD5 had same issue, but fan always worked. And no air was always the case .. heat, flow through(ie. no A/C) or A/C on. We just had no air through any vents.
    And setting the blower to it's 'loudest' setting didn't gave nothing.
    At the time I never thought to check if any air flowing behind the glovebox(as this is where most air was going).
    First thing I though was dead flap motor not sending air to wherever was supposed to go to.
    Pulled dash fascia off and the problem was mightily obvious why no air through vents.
    Some previous gorilla had taken to the heater box with their largest hammer and totally smashed the plastic box into many thousand of shards .. so that all air was channeled behind the dash. That is the flap motors were working to direct air to face, feet, screen, etc., but the path of least resistance for the air was behind the dash/cubby/drivers side .. not the actual vents.
    I glued all the shards, I could find, back together(JB weld) and and added some silicon to the gaps where shards didn't completely seal, and voila! ... air through vents again.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by AK83 View Post
    My current task has me in behind the glovebox.. Maybe I'm getting old*, but I fail to see how a gorilla would fit. Chimpanzees are pretty strong, though.
    *Spent many joyous hours behind the fascias of a few FIAT 124 Coupés in my younger days.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Feb 2024
    Quote Originally Posted by Tins View Post
    Your not wrong!! Quite a steep learning curve lol
    Feb 2024
    Quote Originally Posted by sierrafery View Post
    Unfortunately No codes. Would of liked to see a 33 to be honest . At least that would make sense.
    Feb 2024
    All Fixed...It would seem someone replaced the interior fan but the polarity was wrong and the fan was spinning backwards? So no Flow ...
    Apr 2016
    Country Vic.
    Hmm I'd be a bit worried about that situation, more so than the original problem.
    There are two types of fan plugs(that I know, could be more, but I've only seen two, in my experience).
    I'd say someone has changed the fan, and could only find the other type(of connector). Fans are all the same, and 'some' Toyota Camry fans can fit too.
    But the plug is different. "earlier types have a wider twin parallel spade type connector, later have a T arrangement black spade connector.
    The easy bodge is to cut the wires and then use normal spade connectors to bridge the difference between what your car has, and what the replacement fan is.
    Only problem is typical spade connector types can't handle the up to 40amps of power that the fan can use, so they can burn out.
    This is just guessing on my part here, but from your comment that the wires were 'wrong way around' I'd say this is what's been done down there.
    At least good to see an easy fix for the problem.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
