Thread: Gumtree quartet in D5
    Jul 2023
    Cairns
    Hi
    noise inside cabin sounds like gumtree quartet-or 3 blowflies in a bottle - or a huge mozzie by your ear middle of night.
    kicks in about 50 plus kph, increases in volume with speed but not exactly , varies with bumps,comes and goes eg there one drive not the next, and can be so loud turning up music does not give relief. Have tried aircon on off, fan up down on off, new pollen filter, cleaning out scuttle between windscreen and bonnet as best I can, all to no avail,
    Have had indie lr guy check it and no relief
    did have some gum leaves in scuttle and have removed etc
    any suggestions greatly appreciated
    about to drive Vic to NSW
    noise cancelling headphones have some appeal
    Dale😊
    Tyres? What are they and how worn? Pressures?
    Numb Thumbs
    Fuji White 2019 SE Sd6
    Jul 2023
    Cairns
    Quote Originally Posted by Numb Thumbs View Post
    Numb Thumbs
    Fallen wild peak 20”, 40/42 psi , almost new
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    My thought was something that is peeling/lifting off. Does the sound seem to come from one area (e.g. front or rear or middle of vehicle)? A plastic cover or trim? The grille? I know noises can be a pain but yours obviously goes ballistic at times.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Try dropping the tyre pressures to 35/38 psi.
    If you can get it on a hoist, have a very careful look underneath for anything loose/able to vibrate. A heat shield maybe?
    Check body trim panels to see if one is loose and able to vibrate.
    These thing do your head in. I get an occasional, high pitched but soft wind noise/whine from near the drivers mirror. Does my head in and it is extremely mild compared to your problem. I drive Melbourne/Sydney/Melbourne regularly over two days and the concrete highway in NSW drives me nuts...
    Good luck!
    Numb Thumbs
