Thread: P38 Air tank to inflate tires
    Mar 2024
    Italy, Roma
    I mounted the springs on my P38, is it possible to use the compressor and the air tank for other uses, such as inflating tyres? has anyone done it?Thank you
    Nov 2015
    Black Rock
    Not really. It is a high pressure, low volume system which relies on exhausted air to cleanse the air dryer cannister. Tyre inflation is low pressure, high volume and is one way. Remember, your air reservoir is only 9 litres. However, you could replace the EAS compressor with one designed for tyre inflation and to fit in the engine bay (ARB make a great dual compressor widely used in Australia). But it is problematic whether you should just simply inflate each tyre direct from the ARB compressor or through the air tank. As the ARB compressor doesn't filter the air like the EAS one, moisture will enter the air tank if you do not add special filters and water traps.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Mar 2024
    Italy, Roma
    ma il serbatoio non ha lo scarico dell'acqua come i compressori di casa?
    e ancora, se passo nell'asciugatrice?
    Stavo pensando di mettere in pressione il serbatoio e dal tubo che arrivava alle valvole, mettere un rubinetto con manometro
    Nov 2015
    Black Rock
    >But doesn't the tank have a water drain like home compressors?
    Yes, and if you're prepared to depressurise it and undo the plug every week or so, that would be fine.
    >And again, if I go through the dryer?
    The desiccant cannister needs to be purged of moisture. EAS does this whenever it needs to expel air. This won't work in a one way system where there are no signals from the computer to expel air from the wheel bags back through the cannister.
    >I was thinking of pressurizing the tank and from the pipe that came to the valves, put a tap with a pressure gauge.
    You are forgetting that a computer controls the whole system. There will be no signals going to the computer telling it to do anything. The only issue you will have is that the compressor will overheat and the thermal switch will cut out. If you by-pass the computer and valve block and just operate the compressor directly, that will work until the compressor fails. And it will fail. It is not designed to do the job you want it to do.
    Mar 2024
    Italy, Roma
    Quote Originally Posted by DieselLSE View Post
    >Ma il serbatoio non ha lo scarico dell'acqua come i compressori di casa?
    Sì, e se sei disposto a depressurizzarlo e staccare la spina ogni settimana circa, andrebbe bene.
    >E ancora, se passo nell'asciugatrice?
    Il contenitore dell'essiccante deve essere spurgato dall'umidità. L'EAS lo fa ogni volta che è necessario espellere l'aria. Questo non funzionerà in un sistema a senso unico in cui non ci sono segnali dal computer per espellere l'aria dalle borse delle ruote attraverso il contenitore.
    >Stavo pensando di pressurizzare il serbatoio e dal tubo che arrivava alle valvole mettere un rubinetto con manometro.
    Stai dimenticando che un computer controlla l'intero sistema. Non ci saranno segnali diretti al computer che gli diranno di fare qualcosa. L'unico problema che avrai è che il compressore si surriscalderà e l'interruttore termico si spegnerà. Se si bypassa il computer e il blocco valvole e si aziona direttamente il compressore, funzionerà fino a quando il compressore non si guasta. E fallirà. Non è progettato per fare il lavoro che vuoi che faccia.
    Thanks, I'll abandon the idea. I will try to use the tank and put an ARB type compressor to charge it
