Results 1 to 4 of 4
Thread: LT230 rebuild.
    May 2015
    Williamstown, Victoria
    LT230 rebuild.
    The work shop has a roof, sort of.
    I have 2 spare LT230 transfer cases. One leaks and the other has noisy bearings. I took the leaky one apart. This is what I found.
    This is not a crushable spacer. Some one has been here before, so why are the O rings on the intermediate shaft square?
    This fell off, no sealant at all. Lots of sealant holding the two bits together.
    Who in the western suburbs of Melbourne could fit the intermediate sleeve?
    Build date 11th Oct 2003
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    I reckon you should go and watch Mike at Brittanica Restorations. He does a lot on these. The intermediate shaft isn't as easy as it seems if the hole is oval. He also has some tips on the collapsible tube/spacer.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2015
    Quote Originally Posted by Tins View Post
    Yes, very nice, I had seen this and I have a spare locking ring, so I can check the preload.
    The other bearings are quiet, silent even. I could get away with a new main shaft seal and a pair of O rings. I am annoyed at paying $10.00 -plus postage for a pair of $2.00 O rings. MLR has them for $17.00. I have a set of O rings, Imperial, not metric. I wonder if they would fit/work.
    LROCV #1410
