Results 1 to 4 of 4
Thread: Nanocom Heat Warning Reset Not Working
    Melrose Park NSW
    I have a 2.4 Puma 130 and use my Nanocom unit for, apart from other things, as a temperature gauge - the Puma temp gauge on the dash lets you know you are getting hot when you go into limp mode. On long uphill grades there are times when the Puma gets up to 100 degrees (I then adjust the selected gear and run the Puma till it runs at a cooler temperature) at which time the Nanocom goes into a warning triangle screen with a reset button. Normally, you hit the Reset to get the full screen back. This has worked fine since I have had the unit. Lately however, when it goes to the triangle warning screen no matter how many times you hit the Reset button it fails to go back to the main screen. This necessitates having to disconnect the plug from the unit, reconnecting and then firing up the unit back through the screens to the one with the temp reading.
    As you can imagine this is a bit difficult while driving. Can anyone let me know how to fix this problem.
    Chenz
    Chenz
    I do not wish to be a member of any club that would have me as a member
    Former Owner of The Red Terror - 1992 Defender 200Tdi
    Edjitmobile - 2008 130 Defender
    Back down the hill.
    Chenz, I think Collin (BBS, Nano manufacturer/vendor) is a member of this forum, PM perhaps.
    Edit: username BBSguy, maybe.
    Melrose Park NSW
    Thanks. I tried to contact him via a PM but got no response. I also sent a chat to Nanocom and as yet they have not gotten back to me.
    Chenz
    Sep 2010
    The Hills.
    152.79 MB
    Cypress is 7 hours behind us. They usually respond, if not immediately.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
