Results 1 to 9 of 9
Thread: Low battery start engine while battery @ 12.9v
    Aug 2010
    Hi all,
    I seem to be having an electrical issue with my D4.
    I keep getting the Low battery start engine message on the dash when parked.
    It will also continue to beep the message every couple of minutes.
    Put the new battery on charge overnight and still get the message.
    Checked for error codes but nothing there.
    Voltage is at 12.9v stable.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Aug 2010
    Also checked out the battery terminals
    Aug 2010
    Also disconnected the Redarc BCDC just in case this was affecting the battery
    Apr 2024
    Newcastle
    Woops wrong thread....edited.
    I have a similar issue. Purchased yesterday, brand new battery a few days ago.
    What i found was battery voltage showing 12.4v after unlocking car. Then about 5 mins later it increased to 12.62v. How much current exactly should it be drawing after unlocking the car to cause that kind of voltage drop?
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Jason.k View Post
    A ****load. When you unlock the car it boots all the computers up. Can be upwards of 20A while they all fire up. Discos are battery powered.
    Apr 2012
    Whyalla, SA
    Rich - did you reset the BMS when the new battery was fitted?
    Aug 2010
    On the D4 or my secondary battery?
    Is that something you can do on the IIDTool?
    Quote Originally Posted by ~Rich~ View Post
    Yes, you will find a BMS reset option available with the GAP tool.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Aug 2010
    Done let's see if that fixes the issue 👌
