Thread: Lost a Parking Globe in the Headlight
    Was changing a blown front parker globe in the front headlight of the RRS (basically the same as a D3).
    I pulled the fitting out that holds the globe but of course the globe fell out of the fitting into the headlight and now sits in the front at the bottom. I thought that with the Hi beam globe out I might have been able to move the parker globe from where it is to the Hi beam spot and out the H7 sized hole there but no, the parker globe to too big to fit through the gap to get there.
    So other than removing the front lens of the entire headlight (needs heating and careful prising apart with risk of cracking) is there another way I might be able to get the globe out.
    It is too wide to fit sideways through its hole and the chance of fluking it and getting the globe to fit the way it went in is pretty small.
    Queensland
    What, you cant remove the headlight and tip it up untill the globe falls out from its hole?
    I know nothing about these modern cars but. Just a thought.
    May 2014
    Point Cook, VIC
    I have done the same with the D3 before.
    By removing the headlight from the car I was able to move the globe around so that the prong end of the globe just starts to come back out, and then using a pair of small pointy nose pliers I was able to grab the end and pull it back out.
    Quote Originally Posted by 123rover50 View Post
    No unless you luck it in - the globe tends to side sideways which is longer than the diameter of the hole.
    Quote Originally Posted by DiscoDB View Post
    You must have been very, very lucky - as I tried for about 15 minutes and never even got close - tempted to modify a pronged gripper and going through the hole but hoping there was a simple option I had missed.
    Dec 2011
    Adelaide
    142.79 MB
    what about a lump of blutak on the end of a piece of plastic coated curtain spring?
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Sep 2010
    The Hills.
    152.79 MB
    Apart from actually crushing the globe and removing it in fragments I'd say it's an exercise in patience testing. It got in there, so it can get out. Like the kid with his head through the fence.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2013
    Darwin
    12.74 MB
    Quote Originally Posted by 101RRS View Post
    Is it a conventional globe with steel base? If so you might try a super magnet, cheap from JayCar. Or insert one of those magnetic ended telescopics and hope you attract it in the right orientation.
    Quote Originally Posted by workingonit View Post
    No was an LED - I will have another go on the weekend as I might be a bit more patient then.
    Blairgowrie, Vic
    Just thinking...
    Did you try a vacuum cleaner sized down to about 15 mm?
    Dizzie, 08 D3 TDV6 SE
