If you removed the metatronics, did you line up the shift mechanism?
Check that you didn't bend pins in the metatronics when fitting the plug
Hi everyone. After changing the metronics seals in the auto filled the trans fluid went to start the vehicle to warm up the fluids for correct level turned on the ignition on and it's displaying an "E" on the dash, with transmission fault, park brake fault and HDC fault. Removed the sump double checked the linkage was located properly and it was. Cleaned the metronic connector. tried clearing the codes but still nothing wont start cant shift out of park. I dont know whats going on. im out of ideas
I have the following fault codes:
Parking Brake
U0101-87 (FLost communication
with transmission control module
Bus signal/message failure missing a
message
Suspension
U0101-87 (2F) Lost communication
message
Terrain Response
Bus signal/message failure missing a message
It doesn't leak oil, Its sweating power
I had same error messages after i fitted sonnax zip kit to gearbox. Turned out electrical plug not seated correctly even though i was sure it was. Tricky spot where that plug is. So i would concentrate on the plug and wiring.
ex 2008 RangeRoverSport TDV8
ex 1995 Discovery 1 300tdi
How full was the transmission when you started? I filled mine to the drain plug. Also, I assume the valve body wasn't split and the solenoids replaved? Check all solenoids are connected properly.
Trany was fully. I did a flush before dropping the pan and replacing zip seals. The car started and ran but still got the F fault ocassionly. So removed the valve body and replaced the zip seals, i didnt split the valve body or touch or replace the solanoids, filled trany till dripped out filler plug tried to start it to warm up the tranny fluid wounldnt start or turn over and got the E fault
Any further details on the E code? When I did my ZF HP28 I had one of the solenoids in the wrong slot(full valve body rebuild including separator plate and zip kit etc) , this threw a code that the gear selected was incorrect, was an A code if I remember correctly, and I believe it's A through F for each gear or clutch pack. If this holds true, then its an issue withthe 5thh gear clutch pack, so it could be a faulty solenoid or zip seal on that line.
Last edited by Eric SDV6SE; 28th May 2024 at 08:30 PM. Reason: Spelling and grammar
Usually with a trans related fault you get an F dash error code not E so i think your problem lies elsewhere.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
