Results 1 to 10 of 15
Thread: Driving lights
    Jan 2012
    Driving lights
    Moving more rural soon…what driving lights / spotties / light bars and fittings are you using?
    Fitting to D4, no bull bar.
    Pro’s / Con’s welcomed
    Back down the hill.
    https://www.fyrlyt.com/?utm_source=g...25476433342508
    Grreat lights but the lens go milky.
    Capel WA
    DRIVING LIGHTS
    Quote Originally Posted by SimmAus View Post
    Have a very close look at the Stedi range and compare them with test results from the internet, you will be surprised.
    Also stay aware of the fact that they are LED and as I found use less power and in my case I did not have to upgrade existing wiring.
    Mar 2012
    Armstrong Creek, Qld
    I have a D3 and find the headlights are more than sufficient for a sedate, night drive home through Skippy Land, with an occasional bovine thrown in.
    I do have a Stedi light bar on the old Tojo, for obvious reasons. It has three facets. Both sides throw in their relative directions i.e. Left and Right and the centre section throws forward. It's not 'Spotlight' efficient, range wise but does light the road well.
    In another post, I said that the only problem is that, when I go from 'High' to 'Low' beam, it's like the headlights have turned off altogether.
    'sit bonum tempora volvunt'
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by Saitch View Post
    Hello Saitch,
    I just went to the Stedi Light Bar webpage (LED Light Bars STEDI™ - High Performance 4WD Lights) and prices vary from $89 up to not far off $900. What option did you choose for the Tojo and why?
    Sorry for the thread hijack SimAus.
    I have also been reading through the FYRLYT Driving light review thread with quite some interest. The candidate for the lighting upgrade is a 1993 Defender 110 with a 200tdi. I doubt that it will mirror the standard headlight's lighting capacity of a Discovery 3-4! Snowy - the Defender came with a ARB bull bar so at least I have something to hang some supplementary lights off.
    Kind regards
    Lionel
    Mar 2012
    Good Morning, Lionel.
    They don't appear to have my exact lightbar.
    My lightbar is quite a few years old (Read 2013 when Stedi started) so I'm pretty sure advances have been made.
    FYI: Mine is O/A Length 570mm, Lens Length 540mm, Lens Ht. 50mm, Ht. from roo bar bracket to top of light 110mm.
    I selected this size, as it fits nicely between the bar's uprights.
    In the third photo, the different sections can been seen.
    One thing with these lights is, if driving at night on a surf beach which has a lot of airborne, salt spray, turning it on is akin to putting a white sheet in front of you.
    NSW SW Slopes
    I dispensed with the driving lights on my D4 that had bi-xenons once I fitted a cheap HID 4500K kit to the high-beam fill-ins with the globe tabs bent forwards to raise the beams. However my son who now owns the D4 has fitted driving lights yet we both live in the same rural area.
    Back down the hill.
    Driving Lights | Spotlights | Thermal | FYRLYT
    All parts of these lights are replaceable, the whole light being serviceable.
    Apr 2012
    Whyalla, SA
    No they dont - theyre Borosilicate glass
    Back down the hill.
    Mine have become opaque, the first were replaced foc, under warranty. The replacements have also gone the same way.
