Originally Posted by
CarlWebb1964
Hi, I'm new to the forum. I recently acquired a 1964 Series 2a. I've been repairing it and now want to put in door rubbers and install the roof, door windows, and rear / side panels. Could anyone tell me where to get the appropriate rubbers and what they are called?
You can get some seals from UK suppliers but the main door seals can vary from absolute rubbish to acceptable.
I sourced some locally which was very close to original, only problem was I had to buy a full roll (50mtr). I then sourced galvanised steel pallet strapping and I've been making my own seals and fitting as per original with original type rivets (not blind rivets)
Series Land Rover door seal
You can get the seals with an internal steel (?) strip and already bent to shape but they are expensive (see below)
Rubber Seal - door top to bottom - 330163 - Paddock Spares
Series Front Door Seal Kit - Right Hand Side - OEM - Paddock Spares
Delivery adds to the cost but it's much, much faster than Australia Post !
Rear/side windows - look for a company locally that supply rubber extrusions. There's usually a windscreen rubber with locking strip that matches the LR profile.
Side panels to tub, there is a fancy profile but a rectangular EPDM foam seal does the trick. I'd have to measure the size.
Side panels to roof. Seal - roof to hardtop RH - 334610 - Paddock Spares
Best of luck,
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
