Thread: Perentie FFR indicator fix
    Oct 2011
    Hi,
    does anyone have any special tips for repairing my indicator switch or is there already a thread about it anywhere? It looks complicated with lots of wires attached. I don’t know where to begin.
    thanks
    lala
    Buy a new one.
    There are budget models
    Defender/110 Indicator/Horn/Dip Switch - STC439C
    and more expensive ones (Lucas).
    Indicator/Headlight Combination Switch - STC439
    Oct 2011
    Buy a new one.
    thanks. I’ll do that. I was also hoping for some help with how to change it over.
    Isn't it just plug and play? I can ask when I go to KLR tomorrow.
    Oct 2011
    Tell Brad you’re asking for eila
    I’ll get the switch from them too.
    Another question - how do I know the problem is in the switch and not somewhere else in the system? The lights work just not the indicator.
    thanks 🙏🏻
    (also I haven’t worked out how to reply without the quote)
    Lala
    I asked one of the mechanics - the switch is just plug and play but the plug is tight and can be hard to push home.
    However, on my way home I realised that to fit the switch, I’m pretty sure the steering wheel has to come off to slide the switch down over the steering column.
    Here’s a video on removing the wheel:
    https://youtu.be/-0z_9d2mK6c'si=wSpPeWNbv0DV5Hyc
    Re your question, I don’t know the Defender/Perentie well enough. I’m going back to KLR tomorrow, I’ll try to have a play with the light switches.
    I checked with one of KLR's mechanics. The steering wheel has to come off to replace the switch.
