Results 1 to 10 of 16
Thread: Looking for the best way to lift a D4
    Jul 2024
    Golden bay
    gday , new to the landrover scene just got a D4 and i am wondering what is the best way to do a lift with this air suspension, ive never dealt with it before ive read there is lift rods , xlifter etc just wondering what is the best course of action
    Thanks very much
    Sep 2014
    Baldivis WA
    Welcome to LR ownership.
    Have a search on here, this has been covered before. The X-LIFTER and LLAMS are the best two options, allowing a few more ride height options.
    With EAS you don't need a permanent lift, this affects centre of mass and your lower control arms and other suspension bits.
    Servicing the air compressor and valve blocks is recommended, again, have a search on here for the detail.
    Jul 2024
    Golden bay
    ah ok cheers, thats what i was wondering if there was a permanent lift so i can put bigger tyres on
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Tim.. View Post
    Gap tool can also do it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2024
    Golden bay
    cheers mate
    Jan 2012
    Depends on what you are trying to achieve / where you are driving.
    The D4 has great flexibility in ride height built in.
    Adding Llams or using a GAP tool will give you better control…but again, what are you thinking / what driving are you thinking about?
    Apr 2012
    Whyalla, SA
    Welcome
    Whats your intended use for the vehicle? 265-60-18 is a perfect tyre size for all-round
    265-65-18 is a nice upgrade and doesnt need a permenant lift.. Im running this until 1pm today and then returning back to 265-60-18 as its just a much nicer all-round experience..
    I have NOT found any benefit from the 265-65 over the 265-60 except a loss of pick up and slightly higher fuel burn - the 265-60 will do all the offroading with ease - and my vehicle spends a LOT of its time doing that
    Permenant lift will increase wear rates on CVs, dents performance and fuel economy, adds some handling dynamic changes when towing.. Hence my return to the next size down this afternoon
    Jul 2024
    Golden bay
    Welcome
    righto mate , yeah im just after as much rubber as possible to deflate for the sand and not being restricted to 40km an hour witht he offroad mode
    Oct 2012
    Rods are available as well to trick the system to stay up and work well and are simple and cheap and removable.
    With tyres let down to 16-18 and DSC off I’ve not found a sand challenge it does not eat up. If you don’t learn the DSC off trick you’ll be bogged in the second car length of sand.
    I’ve got rods but today was the first day I used the height adjustment feature on the Gap tool which was amazing.
    I set the new ‘normal’ height and had this salt water creek to cross so raising to off-road height with the new lift setting gave me extra extension lift to get minimum wetting!
    Jul 2013
    Choose tyres that clear the guards when the suspension is fully deflated or make the clearancing required to fit what ever size bigger tyres you plan to run. If you don't do either of those in the event of a fault that causes the suspension to drop its not going to be pretty if your travelling at speed
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
