8 year service
Had my car serviced yesterday. $6100 later all fixed. Belts, all oils (except auto) front and rear bushes, new fluids. Plus replacement of known weak parts that are best to do while everything is accessable. What has got me tossed is the report that came back from the wheel alignment shop. There seems to be big discrepancies (or is it my imagination) between left and right on all but one alignment result after THEY have adjusted the vehicle. Figures are:
Front Wheels
Toe: .2mm (L) .4mm(R) Total .6mm.
Camber: -1.31 degrees(L) -.44 degrees (R)
Caster: 3.93 degrees (L) 4.20 degrees (R)
Rear Wheels
Toe: 1.6mm (L) 1.5mm (R) 3.1 total
Camber: -.14 degrees (L) .37 degrees (R)
Is it OK there is a difference? If so are mine acceptable or should I query them? especially the last one. One is negative the other positive!!!
2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
