Results 1 to 8 of 8
Thread: Stale smell from AC vents. Cabin Filter?
    Mar 2017
    Tamworth NSW
    I usually haunt the Series One forum, but I thought it might see if any of you Disco II fans might have some ideas. I wonder if any of you have had this problem. I recently didn't use my 8/03 build V8 Discovery II that was left outside for a week. After jumping in and driving off, I noticed a smell from the vents like stale garden cilppings that aggravated my asthma and made me cough. I noticed that the open cell foam strip was all but gone and obviously wasn't doing any filtering.
    Does this model have a replaceable cabin filter like some of the other Land/Range Rover models or just the foam strip? If not, any ideas on how to go about cleaning out the AC blower fan, vents and related parts without having to pull the whole dash apart?
    I have had a lot experience with the early Series Ones but I have a lot to learn about this model, although my Nanocom has helped me cope with the usual faults including the 3 Amigos and Bosch engine management issues.
    Regards, Mike (5380)
    May 2015
    Williamstown, Victoria
    No cabin filter on the D2.
    Build date 11th Oct 2003
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    The foam strip is your lot. But the fan is not a big job at all. Have a peruse of this.
    Mine was absolutely full.... with leaves. Others haven't been so lucky ( guess that depends on your viewpoint ) and have found thankfully deceased rodents in there.
    You will also need to check that the plenum under that foam strip is draining properly through the holes at either end.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    NE Victoria
    32.83 MB
    Are you sure it's coming from the vents, and not wet carpet?
    Tony
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by TonyC View Post
    Tony
    Same solution really...unless it has a sunroof.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Aug 2019
    After removing the plenum on mine, the duct through to fan (circled) was able to be cleaned of leaf matter that had accumulated due to a split plenum. The area under the plenum drains into the inner wings through a hole either end, I cleaned a bunch of detritus out of there also.
    Cheers Discofender
    Mar 2017
    Tamworth NSW
    Pollen Filter.
    Thanks everyone for your assistance. I'll follow your collective advice and helpful suggestions. I reckon that Iv'e got some leaves and dead insects etc clogging up the system. I'll also check that the drain pipe isn't blocked. I'll head down to the local Clark Rubber shop and see if I can find a strip of open cell foam to replace the missing filter strip.
    Hopefully that will keep things clean. Thanks again! 5380.
    Quote Originally Posted by Discofender View Post
    Cheers Discofender
    May 2009
    Tatura, Vic
    Quote Originally Posted by Tins View Post
    Yep, dead mouse in mine. Luckily it is a fairly easy job. After removing a few bits it is only 3 screws that hold the fan in.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
