Great Service in WA from Rover-Tech
					On our current Edjits Adventure through WA my 130 Puma developed a bad transfer case leak which necessitated 500mls+ top up every 1000 klms. Also had a power steering box leak that also required constant top ups. On the way to Perth I contacted Rover-Tech and spoke to Kevin Falconbridge about getting these repaired. Initially he said they were flat out but he moved around his jobs and fitted my vehicle in and did a great job. Changed the Quill Shaft and seals on the transfer case and fixed the steering box leak. When we went to pick it up he told us that the top pin on the front  drivers side brake pad had slipped and was barely hanging in. They fixed that as well. Could not recommend Kevin and the staff at Rover-Tech highly enough. They even gave me a Disco 2 to use for the few days they had it. If you are in WA and need your Landy looked at, they are the ones.
				Chenz
I do not wish to be a member of any club that would have me as a member
Former Owner of The Red Terror - 1992 Defender 200Tdi
Edjitmobile - 2008 130 Defender
