I've been through this with 3 of the 4 doors + the tailgate lock with my D4 and it will be the actuator in the door. After the first couple it becomes an easy job.
LuckyLes
Hey guys,
My D4 also ran into door problem. The passenger side door can be locked using the fob but can not be unlocked. It can be unlocked using the button inside. I can see the button only moves a little bit while the others move properly when pressing the lock/unlock button on the remote. After done some research I think it might not be the actuator fault. Does anyone have the same experience?
LuckyLes
Thanks for sharing. It seems someone did some work around to fix the issue without replacing the actuator. Will give it a go. Here is a youtube link:
https://www.youtube.com/watch?v=izr2tYdf9co&t=310s
Let us know how you get on.
Good luck
LuckyLes
