Results 1 to 4 of 4
Thread: Spare Tyre winder.
    Aug 2016
    Spare Tyre winder.
    I am over this piece of crap engineering. While away recently I had to use my spare. Lowered down but winding half way up it just started cklicking. Lowered again and same result. I took the tyre off and it wound up, no issue at all. Ended up with spare in the back. I have since removed the offending unit and on the bench it winds up and down no problem. Maybe the tyre weight is too much. But I am over this. My question is can you repair these winders. Is there an alternative I could use (other than a rear wheel carrier which I dont want). I thought I read something on this web site but I cannot find it TIA,
    2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
    Sep 2014
    Baldivis WA
    Buy a new Defender,the wheel mounts on the back...
    Mar 2016
    Quote Originally Posted by dirvine View Post
    Same thing happened to mine recently. Ordered a new winder from AliExpress or was it Temu (?) and replaced it. Was easy and around $50. I hear your pain though. I was annoyed too when it happened.
    2007 Audi RS4 (B7)
    Brisbane,some of the time.
    Quote Originally Posted by Eric SDV6SE View Post
    The one on the LC works very well,the one on the D4 was an absolute piece of garbage,like the jack.
    I wonder if it could be retrofitted to a D3/4?
