                                                10th October 2024, 01:17 PM
			Aircon problem
					Aircon issue Discovery 5, any suggestions please.
 Cool air only lasts briefly when operating the air con.  When shut off for 15-20mins it will resume cool air, but only for a brief period again.  Has been tested, compressor ok and system is fully gassed with no leaks.  Autolec has no further suggestions 🤨.  Anyone had similar issues or suggestions.   Thanks in advance before summer heat arrives.
                                                10th October 2024, 03:09 PM
			Aircon problem
					If the gas is checked it’s a relatively common same problem on the D3 and D4 meaning a failed control valve on the compressor. You can replace the valve but given the extreme labour involved it’s better to put a new pump on and be safe you don’t have to do it again.
