Results 1 to 2 of 2
Thread: Early series 2 151 engine Conrod bearings
    May 2014
    Hi all
    just starting the rebuild of of my early 2.25 and while it’s off getting machined thought I go thru the parts sent from turners
    they recommend the td5 Conrod bearings as that’s what they use but the are a bit narrow than the original I do trust turners but wondering if anyone here has fitted them and has any feedback thanks
    1960 series 2 143001010
    1976 series 3 91331709c
    06 discovery v6
    2014 discovery tdv6
    2010 cub supamatic drover
    Narre Warren South
    Quote Originally Posted by Dgd69 View Post
    Hi all
    I can't comment on using the TD5 shells but I had the same problem and read the same solution.
    The TD5 has a bit more power that a 2.25 so the fact that they are narrower shouldn't be a problem
    I was trying to solve a low oil pressure problem, crank journals were OK, ordered what I thought were the correct shells which wouldn't fit and found I had an early engine !
    In the end I found that I had a STD set of NOS shells purchased in a job-lot so I didn't need to go down the TD5 route.
    I did find NOS early shells but they were advertised at crazy prices.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
