I did my injector seals last weekend. not a difficult job and it seems to be going a little better, one injector was clean when I pulled it out, the others were coated in oil so I'm thinking that seal was leaking. I used a generic kit for a Transit and the supplied stretch bolts were too long so I got some correct ones from the dealer for about $12.00. Gave it an oil change with the correct Castrol non DPF oil (as opposed to whet the Castrol site recommends) I guess we'll see what happens. It's got 173K on it and was using about a litre every 1000Km. The only other advice is, don't forget to put the foam sound deadening that surrounds the injectors back when you are reassembling as the injector clamps and the injector lines need to come off to refit it.
Regards,
Tote
2014 Chile Red  L494 RRS Autobiography Supercharged
