It'll be a wiring issue. But where the 12v supply is coming from is a bit of a concern. But first I'd check that the light is wired correctly to park light circuit.
 Master
						Supporter
						Master
						SupporterSo, my latest anomaly to investigate is the front right side indicator on my ARB bulbar which seems to be stuck on.
When I arm/disarm the alarm, all other indicators flash correctly, but this one just stays on.
Before I start investigating the wiring, just checking there's not some setting that keeps this light on? I know on some cars the right side parkers stay on to avoid accidents.
I did have a flat battery two weeks ago which I had replaced and used the IID tool to perform the battery replacement procedure. But didn't touch any other settings.
The battery was 6.5yrs old, so thought it had a good run. But now wondering if this might have hastened its replacement or whether this has happened since replacement. I only noticed this issue last night and after starting stopping, turning lights on/off and arming/disarming a few times, it finally went off. But has recurred today.
Anyone got any ideas?
Nuggets
Discovery 4 3.0L 2010
2013 D4 expedition equipped
1966 Army workshop trailer
 Master
						Supporter
						Master
						SupporterHow very odd. I haven’t touched any lighting circuits.
I removed 6 seized bolts 😔 on the bull bar bash plate and removed the light. There are 2 globes in it and it’s definitely getting 12v to the main one.
I have to head out for a busy day so have just removed the globes and reassembled for now.
I had the dreaded low battery light this morning.
Thanks for the reply.
Nuggets
It is odd. I'm not familiar with the ARB wiring, but they may have supplied a relay. If so, check that. But there's really no need for one, so I'd just check the connection to the parking circuit for that side. I'm wondering if the wire to the bullbar hasn't chafed against a permanent 12v wire but I just don't remember a permanent 12v source in that vicinity. When I get a chance I'll check the workshop wiring manual.
There is a relay for each side that comes in the arb fitting kit so I'd trace the wiring to see if the relays were fitted and then replace the one on that side.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
 Master
						Supporter
						Master
						SupporterNice one. Thanks guys.
However, the plot thickens. After reassembling and driving around a bit to charge the battery, I got a sound I’ve never heard before when I put it in reverse.. the rear parking sensor made a beeping sound I’ve never heard before and the parking sensors button light flashed and then disabled.
i noticed there’s a sensor right next to the light. I think some chafing may be the cause.
Will dismantle and take a proper look tomorrow.
Nuggets
 Master
						Supporter
						Master
						SupporterOne step forward! It was indeed a faulty relay. Nice one loanrangie!
I discovered some very dodgy wiring along the way with twisted, soldered joins wrapped in electrical tape! Not sure who did it. There seems to be a lot of 2010 models around with colour coded non winch bars, so I assume they did some package with arb at the time.
Anyway, will order new wire and replace with conduit.
The parking sensors are still not working. One long beep and then disables.
That will be a challenge for another day
Nuggets
 Super Moderator
						Super Moderator| Search AULRO.com ONLY! | Search All the Web! |
