Thread: Windscreen Ventilator - missing Hinge and pins
    Jun 2008
    Sth East Sth Aust
    Hi
    When I purchased the 80" It came with a detached Windscreen Ventilator and only one hinge, on the Drivers side.
    I have looked at the Parts list, found the part numbers and searched online by name and part numbers for a hinge but have had no luck so far.
    I have found a reconditioned wiper motor - not cheap but original
    and a replica air pre cleaner
    I will gradually get a few missing bits together
    Any guidance where to source the Ventilator hinge - would be great. I guess could make one - but would need an existing one as pattern etc (pdf of hinge attached)
    Nobby
    Image311024111145.pdf
    Totally different to the Defender.
    I wonder if any of these might fit?
    Clevis Pins
    Jun 2008
    Sth East Sth Aust
    Ron ..thats a start
    Ron
    I have one pin on RHS so will measure that up and check - I reckon something there will be close I hope
    now for the hinge - that will be the hard one!
    Nobby
    Clevis Pins
    Narre Warren South
    Quote Originally Posted by NobbyTD5 View Post
    Hi
    I'm confused....you say you have one hinge but you need one as a pattern for the other side ??
    From the .pdf they look identical but assembled differently.
    It should be straightforward making a replacement but you'd have to machine up a rivet to join the two pieces.
    Finding a replacement would be an easier option......best of luck.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jun 2008
    Sth East Sth Aust
    I think you are right!
    Grommit
    thanks !
    Yes - all though they have different part numbers - you are right - you could simply invert one part to use as a pattern for the other.
    Yes If I could find one and buy/swap it etc to would be easier !
    but that might be the fall back - make one using the RHS as a pattern
    Always good to have a different set of eyes !
    Appreciate the thinking!
    Nobby
    Quote Originally Posted by gromit View Post
    Colin
    May 2012
    Wannanup WA
    4.70 MB
    Yes, although they are left and right, it's a pretty simple hinge. Completely baffles me how something like that could be missing! Are the rivet holes there where the hinge should be mounted?
    Jun 2008
    Sth East Sth Aust
    Rivet Holes
    OF
    I agree it is a bit baffling, but I think there is a simple reason. When I inspected the car in sale process - it had no ventilation flap/plate. The seller had one in a shed off a different S1 that suited. One hinge was on the car was missing. So I guess thats why. Yes there are rivet holes in the body and the flap...just no LHS hinge.
    It also had no wiper motor or arm/blades etc - lucky they are easier to find - not cheap though!
    Overall - I think I am lucky it has most things and is in reasonable condition for a 72yo!
    Nobby
    Quote Originally Posted by Old Farang View Post
    May 2012
    Wannanup WA
    4.70 MB
    Windscreen wipers I can understand, as they only came fitted with one from the factory.
    Jul 2009
    S.E.Qld
    It's a very crude arrangement. Ideally, to open the flap the two links should be operated at the same time, which is impossible to do while driving. A 'one at the time' operation puts a lot of strain on the aluminium "L" brackets, and the 2 spot welds will eventually pull out. The unattached flapping about links make it a PITA to raise a lowered wind screen..W.
    Jun 2008
    Sth East Sth Aust
    Agreed - I dont think I will use it much!
    BSF - Thanks
    I agree
    Perhaps this why it evolved to a different form later on ....improvement
    I dont think I will use it much - haven't go a roof - so no problems with ventilation! I will get a canvas top as well - I think too much ventilation will be the problem not too little!
    I just want to get it looking right and functional
    Nobby
    Quote Originally Posted by B.S.F. View Post
