Results 1 to 10 of 17
Thread: Cam cover gasket, sealant?
    May 2015
    Williamstown, Victoria
    I need to change thye Cam cover gasket, yet again. Is lasting three years ok for these? Is it wrthwhile using an RTV?
    Build date 11th Oct 2003
    LROCV #1410
    Jun 2013
    Universe A
    Quote Originally Posted by Bohica View Post
    I think that you need to go genuine with both the gasket and the isolaters.
    Even with genuine it's not a great setup.
    Recently I've been using aviation form-a-gasket, painted both sides and fitted it. I wouldn't use any kind of RTV, at best you make a mess outside, and a terrible mess inside for the next guy to get off (usually you again).
    The aviation stuff makes a mess, wear rubber gloves ... But you can clean up the outside of the engine when you finish with isopropyl alcohol, methylated spirits or even turps.
    I really should redesign it... In my spare time.
    May 2015
    I used genuine, it leaks at the rear. Funny that the VW golf, VW tiguan Mercedes Valente doesn't leak. Land Rover must use **** rubbers and/or a poor design. Thinking a bout it, a lip that sextends below the gasket line on the inside would reduce the amount of oil getting to the gasket. A raised section down the middle on the lower casting would also help.
    LROCV #1410
    Jun 2013
    Universe A
    I think my first move would be to put the top of the cam carrier and the bottom of the rocker cover on a head planing machine....
    May 2015
    Mine only leaks at the rear, I'm not sure a super flat surface would help. I mean to say old chap, the rubber is there to account for the waviness of these surfaces. (Good grief I can see the engineers saying that!)
    LROCV #1410
    Jun 2013
    Universe A
    No doubt you are aware that there are 2 different seals depending on the head version?
    The only difference is the size of the "D" at the back.
    May 2015
    Quote Originally Posted by shack View Post
    Oh yes. Didn't know what the difference was.
    LROCV #1410
    Jun 2013
    Universe A
    If the "D" isn't tight, you've got the wrong one!
    BTW, I have seen a 10p head with the 15p gasket needed, I'm not sure if the cam carrier was replaced or if it was like that from the factory.
    Jul 2014
    west of Transylvania
    You definitely need the dedicated gasket for the engine ERR7094 for 10P or LVP000020 for 15+P, some sealant is needed for 10P but not for 15 and check that drain hole(B in the pic) to be free cos that's one reason for leaks there, i used sealant once when i knew too little about Td5s(not anymore) and it leaked there while that hole was clogged then after i cleaned it was leakless for ages.
    Apr 2016
    Country Vic.
    I also use the brush on forma a gasket stuff, in fact just last week(to get mine past RWC). I'm 99.9% sure I used it on the TD5 back in the day too.
    Previous operator wasted hundred of dollars on copious amounts of a couple of different RTVs. From the amount of oil covering the area, only conclusion was that it was a wasted effort. horrible job trying to get it all out of the nooks and crannys too.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
