Thread: 1991 Classic front door latch pushrods
    Oct 2018
    NSW highlands
    I'm sure this topic has been addressed many times before, but despite searching all over the Internet, I cannot find any useful advice about how to re-attach the pushrods. The one that connects vertically is obvious enough but the other one defies all attempts to see where it connects, let alone replace it.
    Has anyone actually done this? If so, please provide detailed instructions.The various Youtube clips cover everything about the latch plate etc but not one deals with the pushrod connections>
    The schematic attached is good, but doesn't explain the repair sequence RRC door handle linkages.jpgRRC door handle linkages.jpg Is it necessary to reve he unit in the face of the door (item 10 in the schematic) to access the linkages?
    Oct 2018
    NSW highlands
    Update - door latch pushrods
    Please ignore last post. I have foundthe linkage points
    BUT - the outer handle still does not work because it is broken into two pieces and it is the lower part only that actvates the pushrods.
    Does anyone have a replacement right hand side outer door door handle place please?
    Apr 2016
    Country Vic.
    Quote Originally Posted by aussiebushman View Post
    Should be the 'same' as D1 Disco door handles, and disco is more commonly available as a wreck.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    May not matter but Disco will be black not bare metal .
    Oct 2018
    NSW highlands
    Door lock
    Thanks for your advice.
    I finally found and ordered one on eBay. Hoping it is the correct unit as many have the hinge on the left and key on the right. Maybe I'm stupid but I can't see how one would work if differently configured, because the bit that activates the closure it at the bottom of the plate, so it cannot just be turned upside down
    The colour is unimportant - I'm not a purist!
