Results 1 to 9 of 9
Thread: Auto trans no second
    Jan 2013
    WA
    Hi all, looking for pointers before i get started please.
    Auto trans has lost second gear all other gears including reverse are fine even goes into lockup correctly. Stall test comes up good and within speck
    Select D pulls away in 1st but will not change up until 60+ klms when it hen goes into 3rd and acts normally after that
    Nanocom showed no faults.
    Any tips appreciated
    Cheers tt
    D2 2004 TD5 Classic
    Jun 2013
    Universe A
    Quote Originally Posted by thai_tiger View Post
    What happens if you manually select 2nd?
    Jan 2013
    WA
    Quote Originally Posted by shack View Post
    Manually selecting second does the same goes into 1st then nothing just holds 1st as if 2nd has been deleted
    Cheers tt
    D2 2004 TD5 Classic
    Jun 2013
    Universe A
    With your nanocom, you can view the solenoid states.
    Solenoid 1 and 2 are gear solenoids, 3 is for the lockup clutch in the converter.
    I can't remember what the states are for each gear, but if you start off in 1st and watch the solenoids on the nanocom, you should see states change as it tries to select another gear.
    Watch this to see if solenoids change but no noticeable gear change happens.
    That will tell you if it is trying to change or not.
    Report back and we can go from there.
    You can check what version TCU you are running with the nanocom, of you find that can you post it back here please.
    Sep 2010
    The Hills.
    152.79 MB
    Interesting thread. James, can the Nanocom record the solenoid activity?
    Good luck with it t_t.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jun 2013
    Universe A
    Quote Originally Posted by Tins View Post
    Yes it does John.
    If you physically can't feel the shifts but the solenoids are showing on the nanocom that they have been activated, it gives you somewhere to start.
    My guess would be valve body problems, I was thinking sissy a solenoid issue, but that would stop other gears as well.
    And lastly a failing TCU.
    The last one is not likely but it's certainly possible, I've seen one.
    The only thing with the failing TCU is that the firmware is pretty tightly checksummed, so if something becomes corrupt, it should throw a fault.
    There could be a physical problem with something on the PCB though.
    Sep 2010
    The Hills.
    152.79 MB
    Thanks, James. I don't want to hijack t_t's thread, but am interested as mine seems to hold second longer than I like. I don't mind it when the car is cold, but it seems to be happening when it warms up. (I'm going to change the oil back to TransMax when I'm fit enough to get under it. Needs a filter change anyway.) So I'll record a log.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jun 2013
    Universe A
    If you record a log from the Auto Trans section and send that to me or post it back here along with your TCU revision (you can retrieve it with the nanocom) I'll take a look.
    Sep 2010
    The Hills.
    152.79 MB
    Haven’t driven it much over the weekend. Of course, today it is changing normally.
    Who says cars don’t have characters?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
