Thread: C1A20-64 (68) Pressure increases too slow when filling reservoir
    May 2019
    slow when filling reservoir - Algorithm
    based failure - signal plausibility failure
    Hi All
    Looking for some feedback
    D4 AMK Air Compressor last replaced with genuine about 6 years and 70K km ago
    Last week after getting 2 new tyres and driving home I got the above code
    I think the timing was co-incidental, I can't see what the tyre shop could have done to cause issues.
    I did also replace battery 2 days before this.
    To prevent further issues I got it to normal ride height and disabled by putting into build mode with Gap IID.
    I understand this can be issues other than compressor such as a leak or bunged up.
    In the week since disabling the corners haven't dropped, I think rulling out air bag leak, or hoses and valve outlets to the corners.
    I did get this error last year at 2 different times doing water crossings, which I chalked down to a potential wiring issue.
    Last year I did open up and there was no breakdown of the beads or powder / gum build up. I didn't have seal kits but the seals looked healthy enough so replaced beads and put back on. Checked again yesterday and beads are good and no powder / gumming.
    Did some more testing last night
    - using gap iid and service test valves the back and front raised quickly using what's in reservoir, which I think means valve blocks and lines are ok
    - enabled compressor, put it down to access mode, then into off road mode, monitoring gap iid, with valves closed, it took over 7 minutes for gallery pressure to rise from about 165 to 240 PSI which I assume is too slow, can anyone confirm. It cut out with fault code again
    - I sprayed sudsy water around centre valve block, compressor and reservoir and while it was dark no obvious leaks bubbling
    - I disabled compressor while reservoir was open and filling while gallery was at high pressures, over maybe 10 minutes pressure dropped by maybe 6 or 7 psi
    To rule out other issues before spending $s on a new compressor what else should I do
    - replace seals
    - could the front or rear valve be leakeding i.e. just at connection back to central valve block, if corners are not dropping ?
    - anything else ?
    - pressure sensor replacement ?
    2010 Discovery 4 3.0L TDV6 ~180K
    Nov 2015
    Black Rock
    After 15 years and 180,000km, the compressor has done its job and needs replacing.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Oct 2016
    Perth, AU
    Quote Originally Posted by DieselLSE View Post
    Only it was 6 years and 70k km ago - a little early for failure, though not completely unheard of i agree.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Nov 2015
    Black Rock
    Quote Originally Posted by veebs View Post
    Oops! Sorry. May be worth cleaning out the valve blocks and lines first.
    May 2019
    Do you think I need to look at the front and rear valve block or maybe just the centre one. When I use gap iid and service test valves option, the front and back pop up very quickly it's just the time to build pressure seems to be an issue after I have moved the height once or twice and air in reservoir is lowered.
    I know for valves people take them apart and clean and replaced seals, it no sign of sum / powder or decicant break down then I assume airlines are ok, but how do people clean them out ? Compressor ?
    May 2019
    I will look at alternator health also due to needing to replace battery, I am guessing low voltage to the pump might also impact its performance ?
    Feb 2012
    Darwin
    Sorry had to remove my post as it was related to fill too quick, not fill too slow.
    Cheers, Mungus.
    _________________
    MY14D4HSE, Nara Bronze, E-Diff, Vision Assist, Surround Cameras, LLAMS, ProSpeed Sliders/Compressor plate, Mitch Hitch,
    ARB Summit Bar, Runva 11XP, Traxide D3-DU, GOE Comp. Rims, D697 265/60R18, Rijidij RWC, Fyrlyts.
    May 2016
    Londonderry, NSW
    I had a similar occurrence although my compressor was a Hitachi. My fault ended up being the output solenoid on the compressor, I fixed it with new seals etc. Now I am not sure whether the AMK has this or not but it is worth having a look especially if you still have the old one.
    St Helena,Melbourne
    1.13 MB
    I would start with a drier service kit and exhaust valve, after 6 years it should still be ok and only require a service.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2019
    I replaced filter and dryer and o-rings, but ended up replacing compressor and all good. I suspect there was a hairline crack or something and compressor is bdes up getting wet
