That’s not many kms.
You can change the bearings with engine in car removing the sump and oil pump.
Have you updated the oil pump?
Seems unusual unless it’s about to destroy itself.
I’d also make sure the pressure switch is not at fault.
For a little while now, I've been getting the low engine oil pressure light coming on at odd times. Indie has diagnosed it as most probably worn bearings. Car has done 185,000km with regular 10,000km oil and filter changes (along with regular flushes). Use has mostly been country driving, with very little stop/start city driving or short trips.
So, I'm joining the steadily growing list of TD/SDV6 engine failures. I certainly won't be driving it until it completely fails.
So, whilst looking at replacement options (Defender Hardtop, Grenadier) I'd probably much prefer to either put in a new block (and upgrade the inlet manifolds to aluminium) or strip my TDV6 down and upgrade the bearings and rebuild it. That, along perhaps with a gearbox overhaul and a few other bits and pieces would probably see the car last another decade or so which should see me out in terms of outback/bush travel.
2013 D4 expedition equipped
1966 Army workshop trailer
Change the oil filter and cut the old one open see if there any shiny bits. Seems to a better indication of bearing or other metal failings.
There is no eraser on the pencil of life.
Now - Not a Land Rover (2018 Dmax)
Was - 2008 D3 SE 4.0l V6
Was - 2000 D2 TD5 with much fruit.
Ray
The rear seal should be changed given its age (it's probably already weeping) and that the old rubber won't like the crankshaft being slightly lowered when changing the mains.
There's not much work room around the crankshaft to be changing the bearings from underneath, especially with no bearing tabs to keep the shells in position while tightening the bolts.
If you consider the Grenadier I strongly advise the same as I tell people who are considering buying a LR.
sign up to the forum and do a lot of reading before you commit
Put a small lift in them and the front drive shaft fails, numerous electrical problems, heating and cooling problems, oil leaks, water leaks.
then there is the lack of service availability due to very limited dealers, dealers stopping Grenadier sales due to lack of sales and support from Ineos, no service manuals as promised and no aftermarket scan tool so you can’t even reset the service interval.
I would already own a Grenadier if they were half what was promised but sadly they have missed the mark on many fronts
i still wait and watch with hope because they are fantastic in design and engineering
Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
I have read of plenty of electrical isssues, water leaks (especially the front sunroofs).
A Grenadier owner turned up to my place (I sold him some Rangie parts). He showed me the common water leaks (sills and sunroofs). His car had been back to the dealer for multiple repairs…. And it still leaks.
Interesting he also owns a new Defender. When I quizzed him he said “you simply can’t compare a new Defender and Grenadier - they completely different vehicles”
His favourite? The Defender.
I expressed my interest in the Grenadier (I said “in a few years when they have ironed out the bugs”) and he said “Don’t hold your breath - I can’t see them lasting much longer. There are rumours they are in trouble “…
88 Perentie FFR - Club Rego
93 Discovery 1 200 Tdi - Club Rego
03 130 Td5 Single Cab
06 Discovery 3 Petrol
22 Defender 90 - Full rego
Well you really red to have a good look at the Grenadier forum, it’s not one front drive shaft failure it’s a failure that has or will shortly happen to every lifted Grenadier
I am waiting a minimum of a few years to see how the whole project pans out, at this stage they have issues a plenty and no solid fixes or help from Ineos
185K is nothing. I'd look further than bearings.
As for another, well the new Ranger SuperDuty looks like it will be awesome, if you can deal with a dual cab. (Wonder if Ford will bring some of the upgrades to the Everest). 4500kg towing is a game changer. With ball weight scales built in, ffs.
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
Lots have failed at less than 150K as reported by the owners on this forum although mostly 3.0 engines.
