Results 1 to 3 of 3
Thread: shims for diffs
    Dec 2021
    shims for diffs
    Hi, I was wondering if anyone knows where I might get shims (pinion end and flange end) for my 1958 109 diffs in Australia - I haven't been able to locate any at the usual suppliers?
    The UK shops tend to be out of stock or charging in the range of 5-15 pounds per individual shim depending on the shop and the shim thickness.
    A friend has suggested cutting my own shims from shim metal sheets - if I did, how precise I would need to be in terms of the inner and outer diameters?
    Thanks in advance for any and all advice.
    Wayne
    Narre Warren South
    A company that rebuild diffs might be able to help.
    Ashcroft in the UK supply a 'kit' at reasonable price.
    Rover Diff Shim Kit - Ashcroft Transmissions
    Same kit here :-
    Diff Pinion Height Shim Kits
    – KINGPIN Fab
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2021
    Thanks Colin -I will order a set.
