Results 1 to 10 of 32
Thread: what electric brake controller?
    Jul 2012
    Toogoom, QLD
    Gents,
    I'm looking to get myself a caravan end of the year, 2500kg and investigating brake controllers. I have read about the blue tooth type which while they sound easy I am not sure I would trust a blue tooth connection with brakes function.
    What unit are people getting and why?
    TIA
    Peter
    St Helena,Melbourne
    4.28 MB
    Red Arc tow pro elite is probably the best on the market.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW Far South Coast
    The general statement is that the Redarc Pro is the best.
    I DONT agree!
    Its very good, but, like most Redarc products its just too expensive.
    For 1/2 the price you can get a Haymen Reece IQ compact.
    It works the same (proportional), but has the advantage that you can adjust the boost control, ie manual control, as you drive. With the Redarc you have to stop to make the change to manual control and it is on or off, not adjustable.
    1/2 the price and better to boot!
    PS. I've used both.
    Trevor
    Jul 2012
    Toogoom, QLD
    Quote Originally Posted by ytt105 View Post
    I DONT agree!
    PS. I've used both.
    Trevor
    thanks mate, last one I had was early 80s and it used a hydraulic feed from a tee after the brake booster plus one from brake pedal light CCT to trigger van brake lights. Having said that it was adjustable and worked exceedingly well.
    St Helena,Melbourne
    4.28 MB
    I DONT agree!
    PS. I've used both.
    Trevor
    around $260 is hardly expensive.
    1974 VW Kombi bus
    Mar 2012
    melbourne
    Redarc because it was in the car when I bought it
    works a treat and is easily adjustable while driving and is easy to apply the van brakes if a sway starts
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Apr 2012
    Whyalla, SA
    I DONT agree!
    PS. I've used both.
    Trevor
    Trevor
    The Tow Pro ELITE is the current version, that compares to the HR Compact IQ.
    RRP of the HR is $350, often selling at $199. The TP Elite V3 is often seen for around $260. For that $61.00 the product is vastly superior.
    It is adjustable, and has offroad overrides
    Is installation is more versatile - unit can be mounted anywhere and the connecting cable made to suit if desired.
    It has a cleaner in cab appearance with one less hole required.
    NSW Far South Coast
    https://www.ebay.com.au/itm/38481475...Bk9SR5yTl5DZZQ
    Less than $150!
    Mounts the same as the Redarc, works better!
    Can use the adjustable, manual mode WITHOUT stopping.
    Sorry, no contest.
    Trevor
    Mar 2016
    Less than $150!
    Sorry, no contest.
    Trevor
    Vomit. Looks like a toy. I love my Elite. Redarc FTW what electric brake controller?
    2007 Audi RS4 (B7)
    Mar 2012
    melbourne
    Why are people claiming you have to stop to adjust a redarc ?
    I have towed 1000’’s of km and never needed to stop to adjust it and have adjusted it 100’s of times to suit the conditions on the fly, it also works an absolute treat so a bit confused on why the hate from a few
