Hi All,
I'm new to Disco 5 after 8 years of owning a D4.
I have a 2019 SD6 HSE Lux, when i turn the engine off, I can hear the charge air coolant pump continue to run for several minutes after. It's a low hum but changes in pitch (sounds a bit odd). My question is, is this normal or do I have an issue? Gap IID shows no related faults.
Also, when the car is off, even when locked, i hear a rhythmic click coming from the rear of the engine somewhere - when this happens i also hear a relay in the engine junction box click on and off (seemingly in response - its ever so slightly timed after the initial click which i can't pinpoint). The relay is R2 for the main air fan. I also think i can hear another relay nearby clicking on and off.
Is this also normal, or any clues?
Cheers.
Matt
2010 D4 TDV6 HSE | 2019 D5 SD6 HSE Lux
