Results 1 to 4 of 4
Thread: CDL & Terrain Response
    TonyC is offline Wizard Silver Subscriber
    NE Victoria
    32.83 MB
    Hi All.
    Is the centre diff in the D4 transfer case either locked or unlocked, or is it like the rear eDiff, in that it has variable lock up?
    If it's either locked or unlocked, is it locked in all terrain modes other than road?
    Other than "Rocks & Ruts" calling for off road hight and low range, are the the different Terrain Response modes just how aggressive the traction control kicks in?
    Where does the eDiff fit in to all this? Is it controled by the traction control, or does it just sit in the back doing its own thing?
    Tony
    Sep 2010
    The Hills.
    152.79 MB
    A whole new world to explore eh Tony? Or should I say rabbit holes to fall down?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jan 2010
    AlertMe
    The centre diff is variable locking at whatever percentage the car decides, and is most locked in Rock mode as you don't want a lifted and spinning wheel to come down to a virtual stop on a rock and shatter a cv, etc. The traction control also alters the engine, suspension and gearbox programmes. For, a quick demo put it Sand mode and see how peppy acceleration is from a standstill.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Mar 2012
    melbourne
    Transfer case is variable with its lock up, it does vary depending on what terrain response is selected, rock crawl is the best for full lock up and most responsive TC
    Sand always takes me a bit to get used to as I don’t do a lot of sand driving so always seem to get stuck easily on the first day of it, after that I seem to suss it out a bit, personally I think the accelerator response is to aggressive which takes a bit to get used to so you don’t just bog down, I never had issues on sand in the old Disco 1 which is a near unstoppable weapon on soft sand
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
