Thread: Dimensions of RTC5311 hub seal
    Jun 2025
    Out and about
    G'day folks, I had to register under a new user name as I'm out travelling and have no idea what my password is...I'm on my way out to the western deserts and want to carry a couple of hub seals in my emergency spares, I'd forgotten that I used my spares and hadn't replaced them. Can anyone tell me the dimensions so I can grab some generic seals from a bearing supply please. POD.
    (Alternatively if someone knows a place in Mildura or Port Agusta or between who would have the proper ones, even better)
    Jun 2013
    Universe A
    Quote Originally Posted by Roadkill View Post
    We use Spencer golf bearings in Whyalla a lot, not sure if they can cross reference that number, but I'd definitely give them a shout, fantastic to deal with as well.
    Jun 2013
    Universe A
    Can you double check that part number please?
    NE Victoria
    32.83 MB
    I'm getting
    80.2 OD on the main body
    82.8 OD on the little lip
    57.9 ID to the lip on the open side of the seal
    59.5 ID to the lip on the closed side of the seal
    12.0 thick
    The ID measurements are as close as I can get as the inner lips are flexible.
    The OD is rubber covered
    It's a Corteco seal and has the following written on it
    IN50499
    GACO
    2
    ANGUS
    The Corteco box has part no. 15510067
    Tony
    NE Victoria
    32.83 MB
    Quote Originally Posted by shack View Post
    RTC3511 is the number on my Corteco double lip hub seal
    Tony
    Jun 2025
    Out and about
    Thanks very much chaps, yes it seems I mis-remembered the part number. I'll find an industrial supplier in Mildura in the morning and see if I can get a couple of generic seals 80x60x10, should suffice for emergency spares. Much appreciated.
    Jun 2025
    Out and about
    Thanks again for the help fella, picked up a couple of basic seals in Mildura with no trouble. Currently cursing myself for leaving my spare brake pads somewhere at home! Just posted an SOS thread.
