Results 1 to 10 of 11
Thread: Air over Hydraulic brakes
    May 2003
    On The Road
    Lucky Dogs has air over hydraulic 4 wheel full size truck drum brakes.
    Do I have to remove the wheel and drum to adjust them?
    Please rotate your eyes 90deg clockwise.....
    Back down the hill.
    I wouldn't think so, Pedro. You need to turn the wheel as you adjust it, so there must be an adjuster somewhere on the backing plate.
    Full air has been an industry standard in Australia for over fifty years.
    Mar 2010
    Queensland
    12.97 MB
    Hello Pedro and V8 Ian,
    I have been waiting for someone to mention air brakes. Ian, your towing my D1210 International ex-Telecom Linesman's van is no doubt one of your fond memories. That vehicle came fitted with pneumatic brakes for the plant trailers those trucks/vans routinely towed. Back in the 1970s and 80s the pneumatic controlled trailer brakes might have represented the peak of technology. While this van is placed as Number 2 on my list of priority restoration jobs - Snowy my 110 Defender currently holds pole position.
    When its place on the grid comes up - is there much point remaining faithful to the van's now old pneumatic technology? Or would it be more reliable and easier to go up to the flash wireless electric trailer brake controller technology? Or my taking one step backward, to the hard-wired brake controller technology?
    Hopefully, the type of brakes I am referring to match what Pedro started this thread about. Sorry for the hijacking of the thread - Pedro!
    Kind regards
    Lionel
    Back down the hill.
    Lionel, I think your van has vacuum boosted trailer brakes.
    Mar 2010
    Queensland
    12.97 MB
    G'day Ian,
    Well you know, Ian - them ones too!
    Are they still used? Is it worthwhile retaining them - even if it is to continue with them just for appearances as a homage to the past? Knowing they may never be used? Or who knows, one day I might encounter a trailer with those brakes.
    My trailer is a electric controlled wired unit for the brakes, so I would need to put a controller in the cabin anyway.
    Kind regards
    Lionel
    Back down the hill.
    Your call Lionel, but I doubt you'd encounter a vacuum trailer these days. In your position I'd have thought wi-fi brakes the most practical, considering its portability.
    Mar 2010
    Queensland
    12.97 MB
    Hello Ian,
    Yes, I may just retrain the fittings at the back in homage to how these vans were fitted out when my Dad drove them as a PMG, Telecom, Telstra Linesman. While modernising the actual brake controls so they are compatible to my trailer.
    I think I captured all the transitions in the name of the employer Dad stayed with for multiple decades. Post Master General (PMG). BTW. Dad started off in Temora as a Telegram Boy.
    Kind regards
    Lionel
    Sep 2010
    The Hills.
    152.79 MB
    I once drove for a few trips an old Mercedes Benz prime mover that, helpfully, had hydraulic over air. Totally defeated the point, as I discovered in the Adelaide Hills when it blew a hose from the m/cyl. Instead of the brakes automatically being applied, which has been the case on every other PM I've driven, this time I had no brakes at all. And no, it did not have dual circuit. I'd like to tell you that was fun, but I'd be lying.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Back down the hill.
    I think you'll find it was air over hydraulic, John. The hydraulic actually applied the shoes, if it didn't boil.
    Sep 2010
    The Hills.
    152.79 MB
    No. It had a hydraulic master cylinder on the bulkhead that went to a slave that operated the system. Another nice feature of this particular rig was the trailer, which did not have maxis, and so you needed to chock the wheels if you wanted to separate. The he bloke kept all this because it was his first truck. Nine speed roadranger, single axle, but it was a V8 and it flew.
    I spent a day at Strathalbyn, Sunday, where I found a 4wd workshop where the bloke was working on his own car. He was able to make me a new hose in between his own stuff.
    Read what I wrote about the trailer. I really had NO brakes. Even then, I was used to Scanias. F12 etc. I had no idea that trucks like this one existed. I learned about air over hydraulic on Bendiz systems in the Army. I know the difference.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
