Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Soldering brass.
    Sep 2010
    The Hills.
    152.79 MB
    Soldering brass.
    In yet another fit of stupidity I bought a saxophone. No, I can't play. I want to though.
    This sax is around 80 years old, beautiful Italian thing, but it looks like it spent the last few years in the toddlers room at a creche. Ok, I reckon I can deal with most of the damage, but it needs some of the key posts reattached. Solder seems to be the go, the brass is too thin to cope with the heat of brazing. Trouble is, there are too many conflicting opinions on the internet ( NO! ) as to what to use. Lead free solder, various forms of silver solder, etc... Now, I can solder ok, but this needs a torch, which I have. I guess my question is, does anyone here have real world experience with soldering thin brass, for instrument repair or maybe jewellery? Right now I'm focussing on disassembling the thing, with all its bent rods......
    Once I fix it I will have another way to annoy the long suffering neighbours.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2009
    Hobart
    Hi,
    301 Moved
    May be able to help. He lives locally, (Hobart) but may respond to email or phone call .
    In my experience, thin brass is easy to solder (with a soldering iron) - except that it is an excellent conductor of heat. Preheating with a heat gun I have found helpful, a torch would work as well. The advantage of using a soldering iron is it is easier to get the solder only where you want it, which depending on what part you are soldering, may be fairly critical, if only because the solder is a different colour.
    As to what solder to use - depends on what bit you are soldering, but my guess is that for most bits which have low stress on the joint, it will not be critical. If it is a previously soldered joint, I suspect that in view of its age, the original was probably traditional lead/tin solder, although today I would suggest lead free, if only from a workman's health perspective.
    Mar 2018
    Perth (near Malaga)
    I use a leaded solder with silver for really thin brass. It's a Sn62Pb36Ag2 composition.
    I've found a couple of really good youtube channels over the years on musical instrument repair. I have a "Smith Little" torch I use with Oxy/Propylene for a teeny pinpoint flame.
    Never done a brass instrument, but I watched a lot of instrument repair videos to get a technique I use for soldering brass shim-stock.
    One trick I learned is to get an old pair of socks. I soak them and wrap them either side of the bit I want to solder to stop the heat spreading too much. That and I use a 2B pencil to draw around (dirty up) the area I'm working on to stop the solder spreading too far.
    Take some pics. Love to see some before and afters.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by BradC View Post
    Thanks very much for this, Err, Brad... . Especially the tip about the socks. I was wondering about some sort of thermal bandages but that's much simpler.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Oh, and there will be pics. It's the only way I will be able to put the thing back together.
    I have also found a couple of channels for instrument repair. But in my case it becomes another rabbit hole to get lost in, which is why I asked here.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    This guy is interesting to me, well at least this series is. Makes it approachable.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Queensland
    Watching with interest. I have a single barrel shotgun I want to put a front sight on. I will use a brass bush made to fit the OD then solder on the bits to make the sight. I have a little coil of silver solder but dont know if it has its own flux.(label gone) if not will have to buy one. Was going to try first, so now I will wait for your trial.
    Keith
    1963 ex Woomera Ambulance sold
    1950 Tickford Station Wagon sold
    1954 Royal Review sold
    Perentie 6x6 Forward Control Camper sold
    1957 SWB Hard top with 200TDI,.
    . 1965 2A Forward Control Camper.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by 123rover50 View Post
    Keith
    I did that once on a little .410. Didn't trim the end inside the barrel. First shot and I had to do it again
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Bit of looking, I can find that as a paste, which I can get from Mouser, and others I suspect. Is paste what you mean?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
