Results 1 to 10 of 11
Thread: Discovery 2 air compressor reliability
    Oct 2025
    South Island
    2.79 MB
    Hey guys I've just acquired my first land rover, a discovery 2 with air suspension on the rear that currently is having some issues. The compressor at the moment isn't working, and blows fuses if I replace them so it is currently running on some plumbing connectors with the bags hosed together with a fitting for my battery air compressor.
    I have a new replacement compressor coming and some proper hose fittings to repair the airbag lines properly, but my concern is how reliable the air compressor is being on the bottom of the truck out in the elements. It feels like a waste of time to fix the lines and replace the compressor if it can't handle getting wet, so I want some opinions from people who have used these trucks and know how the compressors last on them
    Back down the hill.
    I've found the compressor to be sturdy and reliable, not prone to failure from elemental issues.
    Oct 2025
    South Island
    2.79 MB
    Awesome, I've got about $600 of bits and pieces for it coming, figured I should ask about that compressor before I waste my time doing all the work I've got planned. My other trucks a new Navara, and any drop of water around my transfer case causes it to go bananas....
    Back down the hill.
    Google Airbag Andy.
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by Adarewyr View Post
    As mentioned, they are a robust unit, they generally only fail if a leaking airbag or fitting is ignored for a long time, making the compressor work overtime.
    Google Airbag Andy.
    I think you mean Bagpiping Andy, I guess it's an airbag of sorts.
    Sep 2010
    The Hills.
    152.79 MB
    Seems to have had a name change or a change of ownership.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2014
    west of Transylvania
    Mine is still the factory fitted one, i only replaced it's piston seal and drier once about a year ago but i keep changing the filter once a year(i make them myself) that's all.
    Oct 2025
    South Island
    2.79 MB
    Quote Originally Posted by sierrafery View Post
    Awesome, my compressor didn't seem to be running at all so I have a replacement in bound, hopefully a new unit will sort whatever issue it had. It was blowing fuses the second the height adjustment button was pressed
    Oct 2025
    South Island
    2.79 MB
    Hey guys I've got my new compressor in and run some new airlines with valves to allow me to manually pump the bags if required, but I've noticed one side is sitting higher than the other by a good 50mm or so. Any ideas on this? I have some cheap replacement sensors to go on but unsure if they will require a computer to program them to my vehicle or if they will just plug straight in and be good to go.
    Appreciate any advice
    Jul 2014
    Hi, calibration with nanocom or similar is needed, no way around that
