Thread: ENV diffs
    Dec 2025
    UK
    ENV diffs
    Hi
    I have some ENV diffs which I acquired with a job lot of spares.
    How can I tell which vehicle (Land Rover??) they fit?
    I also have axle tubes - again I don't know what they fit
    Queensland
    They were fitted to the 2A and B Forward Controls and I think the one tonner too. On the rear originally but later to the front also.I am a bit hazy on the details now but the were not particularly strong. There was a little pinion bearing the other side of the crown wheel and the casting seemed a bit weak. I broke mine so removed them and fitted Salisburys.
    Keith
    1963 ex Woomera Ambulance sold
    1950 Tickford Station Wagon sold
    1954 Royal Review sold
    Perentie 6x6 Forward Control Camper sold
    1957 SWB Hard top with 200TDI,.
    . 1965 2A Forward Control Camper.
    As Keith says, pretty much. The ENV axles were only on the 2B 110 forward Control, and, I believe, on the One Ton, although note that the One Ton was never sold in Australia. I believe two, maybe three may have actually found their way here.
    The 2B, however, was moderately successful in Australia, although I think the later ones had salisbury axles, so the ones you note probably came from them.
    Dec 2025
    UK
    ENV diffs
    Quote Originally Posted by BillD View Post
    Hi
    Thanks for the replies. One diff has 5.57 painted on it - would this be the ratio? From what I have read elsewhere in the Forum the ratio is 4 something (I can't find the original post!)
    I think the standard ratio is 4.7:1, so it is quite likely that the one with 5.57 painted on it has a non-standard ratio.
