Results 1 to 2 of 2
Thread: 18" rims on an SDV6 D4
    Feb 2026
    South Australia
    Gday, who has 265/65/18 (31.6") on Tuffant wheels on a D4 with the bigger SDV6 brakes without Johnson Rods? By my measurements the front arch plastic and chassis horns will need "massaging".
    The steel Pilbara rims only come in +29 offset. My Black Design 19's are +53 and I'm a bit worried the tyres will stick out. It's near impossible to get 19's in a size that gives 31"to 32" diameter in an Allterrain so going down the 18"road for rims. Cheers
    St Helena,Melbourne
    4.28 MB
    With the increased offset you may not need any work, i have 265/65/18 Wildpeaks on my D3 and the front left guard liner required some persuasion with a heat gun on the inner right.
    No clearance issue on horns with stock offset rims and i use a Llams when i need a height increase but normal height is fine.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
