Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Gearbox Cooling - Defender
    Normanhurst, NSW
    Has anyone been successful in getting the gearbox of their Defender Xtreme to run a bit cooler and not generate so much heat around the seat box. Is there an oil that runs cooler or is ducting some air onto it the answer. I'd be interested in any suggestions.
    I have had this problem in my previous 200Tdi Defender and now in the Xtreme and with summer rapidly approaching I figure it's about time I did something about it.
    Roger
    Ruslan Guest
    I noticed heating when I was using CDL and low range for a long time continuously. After changing driving style and getting know car limitations I apply CDL only in real critical situations.
    Ruslan
    Gilderoy, Victoria
    Does it not have an oil cooler on it?
    R380 has provision for fitment of an oil cooler. I know the 130's have them fitted.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    99.87 MB
    I'm pretty sure the D2 R380 also runs a cooler.
    Are you sure its not engine/exhaust heat?
    Slunnie
    Ive seen a somewhat dodgy improvisation done on a series transmission..
    a pair of tpieces were plumbed onto the filler and drain plugs one side was fitted with bungs and the other side went to an oil cooler plumbed under the tray at the rear above the popshaft.
    Depending on how much cooling you want it might be enough
    JamesH Guest
    I've had a similar symptom (hot under seat boxes esp drivers side) in the past on long runs but not always. A mechanically minded mate got underneath and felt around and decided that it was like the handbrake was rubbing. We tested the brake, it was working, we released it, it rolled easy but it was very hot there. We even got under his Defender that had been following and his was cool as a cucumber.
    Being as we were, out in bloody whoop whoop there was not much to do but keep going and keep an eye on it. Anyway the problem disappeared the next day. On this years trip it re-occurred, once. I though hmm here it is again. Next day gone.
    Now it MAY have been because on the gravel shaly track I had diff lock on and my mate didn't but I don't think I did have diff lock on at that time. Next time it happens and I have the CDL on I'll take it off.
    NSW far north coast
    Quote Originally Posted by D110V8D
    Ummm, not all 130's have them fitted. Later model Tdi 130's don't, but all the Td5's I've looked at seem to have them.
    Gilderoy, Victoria
    Whoops!
    As usual my technical knowledge sucks ass!
    Mick
    I'd be surprised if the gearbox was the source of the heat, although it will generate a bit, but it would be pretty minimal compared to the heat from the engine and exhaust , all of which flows back under the vehicle pushed by both fan and forward motion. Of course, a dragging handbrake will make a bit of an impression as well. I cannot see how diff lock in or out would make much difference, and if it did, the locked diff would generate less heat as there is a set of gears not working under load.
    Normanhurst, NSW
    Unhappy
    Thanks for all the comments guys but it seems that I need to clarify a few points.
    • The heating problem is continuous but varies depending on the ambient temperature.
    • It is most noticable on the seat box in the vicinity of the gearbox.
    • It occurs with and without CDL engaged but is most noticible (and annoying) when on the blacktop.
    • The handbrake is not binding.
    • The Xtreme does have an oil cooler.
    • It occurred in exactly the same way on my 200 Tdi Defender.
    So it seems from your comments that it is simply the heat from the exhaust pipe and motor. However I feel that this much heat cannot be good for the gear box, hence my desire to rectify the situation.
    Maybe I just need to do more river crossings to cool the g'box!
    Roger
