Results 1 to 10 of 12
Thread: Trailer Wheel Bearing Seals??
    Hamilton,Vic
    G'Day All,
    Im putting LR hubs on our Dingo OffRoad camper. The bearings are in very good cond and will got into the new hub.
    Ive never changed bearings before so I have a question.
    The seal at the back of the hub....how do you get it out without stuffing it? Are they usally pressed in or sealed with locktite etc? Seems very tight in there.
    Any ideas please?
    Usually you stuff the seal getting it out. They are cheap so don't worry about that.
    Just don't damage the number on the seal, you may need that to get new ones. In fact, get the new ones first.
    Having a tool like the one with the red handle makes it much easier to remove the seal:
    Ron
    Hamilton,Vic
    Thanks or that...They are out.
    All I did was turn the hub so the seal was facing down to workbench, put a brick either side and then got a larhe cold chsile and taped it out.
    Come out with noo probs and no damage at all
    But get this the org bearing are to small for the new hubs ! I cleaned the bearing all up and repacked with new grease,put the rear bearing and seal on and I noticed the whole hub seemed to go back a far way by looking that the axle thread.
    Put front bearing on and slowly eased in but there is about about a 3mm gap between the hub and the bearing and I put the nut on and did it up tight and have leaps of slop.....so I guess back to the trailer place to get bigger bearings after they told me they would fit !
    Somewhere else, QLD
    Pardon me for asking - I know this is a really stupid question, but is the 2nd part of the bearing - the track it runs on, is it still in the hub? That may account for the slop, as LR bearings don't usually get mistaken for others
    In trailer bearings, there appears to be two sizes - Holden and Falcon.
    Which do you have?
    Ron
    Hamilton,Vic
    Quote Originally Posted by langy
    Yep got it in one....I still had the sim's in the hub Oh well Live and learn I guess.
    Hamilton,Vic
    Quote Originally Posted by p38arover
    Which do you have?
    Ron
    Im not really sure....the front is fairly small and the rear is much larger if that helps at all ?????? Im guessing Holden as I think Ford are bigger ?????
    where did you get the hubs from
    been tring to get some and having real probelm. and don't all say that alko or what ever they are. They are bloody useless and keep saying to me . Nah don't do anything for land rovers, can't help you good bye
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Quote Originally Posted by Reads90
    What happens when you:
    (a) Go into ALKO with a printout of their page with the LR hubs listed?
    Or
    (b) You ring up and ask for a price on hub xyz (without mentioning Land Rover)?
    Ron
    Hamilton,Vic
    Mate, I got them from our local Boat, trailer type place. He had to order them in.
    But I was happy at $45 ea including gst, post and nuts.
    Sorry I have no idea where he got them from....cant be that hard....If I can get them here in Hamiton they must be easy to get.
