Results 1 to 8 of 8
Thread: 1980 Range Rover
    dunno Guest
    1980 Range Rover
    Have problem with engine pressurising the cooling system resulting with the discharge of all coolant in about 15 minutes.
    Head gaskets have been replaced but didn't fix the problem.
    Any ideas on where to from here would be appreciated.
    Dunno
    Maryborough QLD
    Bloked radiator or a dodgy thermostst, either of these can cause your overheating woes. Was the water pump replaced when you had your heads done?
    Just a couploe of ideas to get you started. Radiator sounds like it's the issue, it's happen to me before
    Trav
    Newcastle Area
    Radiator cap?
    May 2003
    where ever I fall asleep ,Queensland
    could be numerous probs,what was the original reason for the head gasket replacement ,if it was a previous o/heating prob,did you get the heads machined while they where off,possible warped/cracked heads resulting in pressure into the system
    do you run thermo fans or normal,if thermo check the operation (and direction,dont laugh ,thumpers was running backwards when i bought it!!!!!!) of the thermostat
    other than that what Trav said above
    Quote Originally Posted by dunno
    Is it also overheating?
    Ron
    Dunno
    Where is the coolant going?
    into the oil?
    if so front cover gasket has failed.
    dunno Guest
    Thanks guys. Water is not going into oil its just pressurising the cooling system forcing coolant to blow past radiator cap. Heads were not machined when gaskets replaced and I suspect possible cracked head.
    You have given me a few extra avenues to check prior to pulling motor down again.
    Dunno
    Rayngie Guest
    just had the same problem on my 92 Classic, around town it was perfect, on motorways it shot through water like nothing on earth.
    no water in oil or vice versa, no visible leaks, water was moving around fine, radiator o.k, temp did'nt go up
    Had a mechanic look at it under pressure, when the engine got up to top temp and max pressure, two heater hoses were split and would let water out in large quantity, hence, whenever i ran the engine at idle, no water came out anywhere, so it was only happening under max pressure which is very hard to check for yourself.
    Get someone to check it if you can, i thought it was a gasket, but nope, much simpler fix.....very happy now.
