Results 1 to 10 of 14
Thread: Tx3400
    Tim Guest
    Tx3400
    Just wondering if anybody has fitted a TX 3400 to a new Disco using a bracket without drilling the dash etc.
    Tim
    Melbourne, Australia
    Quote Originally Posted by Tim
    Tim
    D2 or D3
    Don't drill use silastic to affix everything. This is how I have it installed in my D2. Should also work on a D3. Just make sure surfaces are very clean and that pressure is applied whilst it cures.
    Nedlands, WA
    Double sided tape and velcro. I didn't use the bracket either, just attached the head directly.
    Melbourne, outer South East
    I used double sided tape ( good brand like 3M ) or velcro to mount anything that if not too heavy - a control head should be fine. Just make sure that surfaces are thoroughly cleaned with metho first. If it doesn't stay put then consider drilling holes.
    99.87 MB
    Mine is drilled and screwed in.
    Slunnie
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by waynep
    use medicated metho, not normal metho, as normal metho leaves a residue that will affect the joint.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by incisor
    that's a point - where can you get that ? you can get stuff from the chemist called isopropyl alcohol that we used to use in the electronics game for cleaning things, but I am not sure if that is the same thing.
    Dalby
    I mount everything in my vehicles with double sided tape. That foam stuff. This includes the Tx4400 in my old Rodeo and the car kit in our work F250.
    The Tx4400 isn't light but has a large area for lots of tape. However I was surprised that the car phone kit has stayed put considering you are always pushing/pulling the phone.
    The Tx3200 and microphone holder came screwed into my D1 by the previous owner though.
    Tim Guest
    I have found a spot without having to drill any obvious holes. If you pull the tray on the left side of the gear stick selector and the next fitting is held by some fairly tight squeeze clips. I'm planning to fix the TX3400 to the plate underneath and store the main box underneath the head out of sight or under the dash depending on space. It means the head will be at right angle to the driver but no big deal. Anyone else tried this?
