Results 1 to 8 of 8
Thread: ARB Non Winch Bar
    arowanaman Guest
    ARB Non Winch Bar
    Hi All,
    I am a new member to this site. I own a 2000 model Td5 Discovery.
    My disco has a ARB non winch bar fitted, I am looking for someone that has used an engineering shop on the Coast that could modify my bar so that a winch could be fitted. I have seen pics of this done in other states, the identical ARB bar that is fitted to my vehicle was used for the mod. Basically they turned the ARB Non winch bar into an ARB winch bar. The mod cost as little as $80.00
    Any help as to where I could get this mod done would be greatly appreciated.
    Glenn
    Gold Coast, Qld
    Get in touch with Dranged as he should either be able to help or perhaps knows someone who can............Dranged can also fit winches for you as well if you need.
    Good luck.
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Piggabeen (Tweed Heads)
    Winch bar
    Quote Originally Posted by MickG
    Good luck.
    There is no way I could modify a bar for $80. They must have got a winch cradle section for free from someone and then fitted it.
    Justin
    Gold Coast, Qld
    Quote Originally Posted by DRanged
    Yeah, that does sound very cheap. Let us know how you go arowanaman.
    Aye. Mick
    arowanaman Guest
    The mounting plate is supplied with the winch, so it is just having someone with the equipment that can cut the arb bar and secure the mounting plate, not sure if the mountinmg plate/winch cradle is then bolted or welded in place.
    The fairleads supplied are the same as the warn. Any ideas on what this would cost if all the hardware is supplied.
    Glenn
    Quote Originally Posted by arowanaman
    Glenn
    $45 an hour to do your mods if you are a GCLRO member $55 if not. I would imagine at least 3-4 hrs work, could be less could be more
    Justin
    arowanaman Guest
    Justin
    Do you also fit and wire up winches, would be great to get it all done in one go. I would be looking to get it done in the new year. How do I get in contact with you.
    Glenn
    contact
    I.. send you a PM with my details.
    Justin
