Results 1 to 9 of 9
Thread: Spring / Body Lift
    Brisbane, QLD
    Spring / Body Lift
    Hey Guys.....
    Well after sucessful surgery from Justin on the weekend, the D1 is now wearing 33" wheels. (big thanks to Justin for that.!!)
    But it looks like I'll need to get a bit of lift before I can take her offroad again....or cut a lot more out of the guards.
    I'm looking for some advice on where to get a 2" spring lift and 2" body lift in the Brisbane/Gold Coast area......any help would be appreciated.
    Paul
    Piggabeen (Tweed Heads)
    springs
    You can get an off the shelf spring kit from King Springs at Ashmore. For an off the shelf kit they are good. Just dont ask them for anything outside of the realms of more than 2". MickG has a set of s/hand springs and shocks for sale, they should fit your D1?? maybe a thought. Ask Ricks 4x4 if he can get a bodylift kit from AMV if they do one. Try ARB or Opposite lock they all should be able to supply them. I am not much help as I made mine, so I have never bought them off the shelf.
    How did the Disco drive on the way home?? do you still need some flexi flare rubber as I will get some this week for the Rangie.
    Justin
    PS its always a pleasure to cut someones car up
    Maryborough QLD
    Springs I use the LRA springs (or Graeme Cooper, same thing). They're a bit dearer than the Kings but offer dozens of different combos as well to suit your requirements.
    My Rangie has LRA springs with 180 lb front/220 lb rear whcih offers a soft ride without it wallowing all over the shop. Koni shocks all round as well.
    Body lift, got mine off this site for $50 (second hand 40mm body blocks). Total cost inc. pins, a bit of welding of the rear cargo mounts (spacer) etc.. worked out to less than $100.
    Trav
    Gold Coast, Qld
    If you go for Kings (which I am very impressed with and would recommend) buy from Kim at Mermaid Suspension Miami. For some unknown reason you get exactly the same king springs cheaper from him than from Kings direct. Kings can be very difficuilt to deal with as soon as you start asking vehicle specific questions and I get the feeling they really don't want to deal with the public direct. Kim also fitted my poly air bags and he is great to deal with. Rick sends all his customers there.
    I have a full set of OME springs and shocks but from memory, only the back or the front fit the D1 - Rick would know though plus shocks. More than happy for you to take them, see if they fit/work if you like - there sitting in my garage gathering dust. Got the full OME kit including steering dampner, been on the car for 2 years. Also have 30mm poly urethane spacers as well if you think that will help but not sure either if they will fit a D1.
    Good luck with it all and looking forward to seeing the beast with 33s.
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Brisbane, QLD
    I think the springs are the same for both models (size anyway....the rate maybe different) but the shocks have different mounts so they may not fit.
    My D1 had a 2" lift (supposedly....very sagged now) so my shocks should be long enough already. So I should just be able to borrow your springs and spacers Mick, and chuck them in to see how they look.
    If you are happy to that, let me know, and we can arrange a time for me to pick them up.
    I'll leave the body lift for the mo, as it's a bit more involved that spring/shocks.
    Looks like I've started down a long and expensive path of mods.....but think of all the fun I'll be having with those 33's on
    Quote Originally Posted by Caveman
    Welcome to the club cavman now you are a true member and a road we all will travel. .
    Brisbane, QLD
    Thanks Bolts.....
    I guess I was lucky that my Disco had most of the mods done to it when I bought it, so I haven't really had to spend much on it up to now.
    Looking forward to modding it more though.
    tombraider Guest
    Front springs are different, D2 models have a "tail" on one end. D2 front and Rear shocks do not fit D1.
    And re shocks, if springs have sagged that badly, then its a safe bet shocks are A1 buggered also.
    Gold Coast, Qld
    Happy for you to borrow tham anytime, if you are going to be on the coast between now and Jan 8th let me know and I can arrange for someone to be at home otherwise will swap when I'm back. As Tomberaider said though, my D2 shocks are no use to you and if you have sagged that much then your shocks are probably due to be replaced as well......they will be doing very little I can assure you. Also, fairly sure only front or back springs will fit but Rick or someone would know exactly - also probably a good idea finding out if the spacers will fit a D1.
    Yep, the moddification road is long and bumpy (no pun intended) but then that is half the fun for me. With 33' and some basic suspension mods, you will have yourself a weapon to play with being fully locked etc.
    Looking forward to the next trip and seeing it in action.
    Aye, mick
