Results 1 to 10 of 14
Thread: LT95 Intermediate shaft
    May 2006
    Woolgoolga
    Can someone tell me how to get the shaft out for the intermediate gears in an LT95. Read my manual and says to use an "appropriate puller", anyone know what it is or how do you get it out.
    Gilderoy, Victoria
    Quote from manual reads......
    1 Remove speedometer drive housing.
    2 Remove gearbox bottom cover.
    3 Screw a suitable extractor into the 8mm threaded hole provided in the intermediate gear shaft.
    4 Hold the intermediate gear cluster in position and withdraw the shaft.
    5 Insert the slave shaft RO1003 to retain together the gears assy.
    6 withdraw the intermediate gears assy.
    It go's on further.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    Gilderoy, Victoria
    Without seeing it I cant say for sure but if you screw in a 8mm threaded bolt and use a puller on that somehow??
    Mick
    May 2006
    Woolgoolga
    Mmmmmm... thanks Mick. Now what would that suitable extractor be. I presume the 8mm bolt hole is from the speedo drive housing.
    Is a bit agricultural as I dont have and cant afford the right tools, but I just thread a bolt into the shaft and use a claw hammer under the head of the bolt to lever it out a bit then pull it the rest of the way by hand should come out quite easily once shifted initially.
    Good Luck
    Luke
    May 2006
    Woolgoolga
    thanks Luke, I like your work, will give it a go
    Gilderoy, Victoria
    Slide hammer?
    The "extractor" pics in the manual look pretty similar to a slide hammer with a threaded end on it.
    Mick
    Avoca Beach
    I think its only retained by the friction of the O ring seal once the speedo housing is removed.
    BUT make sure you push it out with the dummy shaft. A broom handle or piece of dowel makes a good dummy shaft. Make sure the dummy shaft is short enough to drop out the bottom of the case with all the gears etc on it.
    Its a long time ago but trust me on this.
    And note the order in which the shims, gears etc come out.
    You then have to inspect all the gears, to see that the wear has not made them too short to contain the bearing cages. Do not skimp on this.
    Regards Philip A
    May 2006
    Woolgoolga
    Thanks Phillip, will be careful. Only pulling it apart to replace gaskets and seals, but wanna know how it all works incase i have to build it one day, at the moment it works fine. touch wood. But wanna once over the bearings and whatever else looks a bit ordinary.
    Yinnar South, Vic
    Replace the needle rollers if they haven't been lately
