Results 1 to 3 of 3
Thread: Electronic Driver Aids, Including the 3 Amigos (ABS- T/C- H/D).
    May 2003
    On The Road
    Exclamation Electronic Driver Aids, Including the 3 Amigos (ABS- T/C- H/D).
    Links to AULRO posts that may fix your problem,
    read these first.
    May 2003
    On The Road
    Please read ALL the threads
    Discovery 2: ABS, Traction Control, Hill Descent Control
    OPTION B--
    https://www.aulro.com/afvb/local_links.php?catid=2
    ABS Fault Diagnosis
    ABS Sensor Repair
    No speedo reading after ABS Sensor replacement until faults cleared
    Fault Clearing after ABS Sensor change
    Replacement of ABS sensor
    ABS sensor replacement - Long Lead
    ABS Modulator Repair
    NOTE: What is now known as the "Option" mod and attributed to a Hummer owner was originally developed by AULRO member Stevo.
    Stevo's original thread documenting the mod can be found below. Unfortunately many pics are now missing, but credit where credit is due.
    shuttle valve switch has arrived
    Text description of what appears to be an early version of "Option B" done by Stevo
    pulled shuttle valves out
    Pull apart examination of failed SVS switch.
    http://landroverclubvi.weebly.com/abs-svs-seals.html
    Bleeding the Brake System
    The use of a NANOCOM to bleed system,,
    D2 ABS Modulator power bleed
    Commercial ABS Modulator Repair Services
    Melbourne based ABS repairer.
    No More 3 Amigo's?
    Off Site links
    Robinson Service
    Overview of Discovery II ABS Issues.
    Repairing ABS problems in the Disco II
    Land Rover Club VI
    Detailed "How-to" covering Option "A" and "B" fixes for the ABS Modulator
    http://landroverclubvi.weebly.com/abs-mod.html
    How to replace Shuttle Valve Seals [common cause of SVS failure and not fixed by Option A or B mods]
    Replacing Shuttle Valve Seals
    Hummer Knowledge Base
    Step by Step pull apart of a WABCO ABS modulator. This is the same unit used in the Disco 2.
    [ame="http://www.hummerknowledgebase.com/brakes/absmod.pdf"]ABS Mod[/ame][PDF]
    Miscellaneous
    How to disable (Defender Td5) ETC properly. Did you know this?
    How to disable ETC properly. Did you know this?
    Last edited by Pedro_The_Swift; 15th September 2022 at 09:50 AM. Reason: Remove dead link//cleanup
    May 2003
    On The Road
