Results 1 to 10 of 19
Thread: Changing my Front springs...NEED HELP
    Central Coast NSW
    Howdy, I am currently trying to change my front springs in my 86 Rangie, but I have hit a snag
    I cant seem to undo the top shock mount, I turn it and even holding the thread with another spanner it still wont budge...any ideas?
    I have jacked the diff up about 1.5" to take the weight but still no joy
    Any tips would be most helpful
    Adelaide - Torrens Park
    If you undo the bottom shock mount and the four nuts that hold the shock tower in you can remove the complete assembly. Then take the shock out of the tower if required.
    Central Coast NSW
    Quote Originally Posted by BigJon View Post
    The bottom shock mount does the same thing, i can barley fit a spanner in there
    How high would you jack the diff up?
    Free Again Thanks Dan
    do you have a rattle gun & aircompressor that semms to work for me well the top mount anyway
    To remove the shockers you don't have to jack the diff up at all. To remove the springs, once the shock is out you have to jack the BODY up and leave the diff where it is. Then the spring can be removed.
    St Helena,Melbourne
    4.28 MB
    Jacking up the car wont do anything, rattlegun or apply heat to expand the nut - or if you are fitting new shocks, grind the f..ker off.
    Pipe wrench on the shock body/ splash guard usually works too.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    terrym Guest
    Hi,
    While jacking up the body just keep an eye on the brake lines, they don't stretch
    LoadedDisco Guest
    Give it a spray with WD - 40 might give it what it needs if some spay works in under the nut.
    Quote Originally Posted by The Dude View Post
    well i always end up useing an electric spanner (aka angle grinder)
    Never have amanaged to get a front shock of and able to use it again. So when ever i am changing the front springs always replace the shocks anyway
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Would you like some help from a local Boring rude Pri**?
